Browse Forums Building A New House 1 Sep 03, 2022 2:10 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi all. We've just purchased the Mercator Samos ceiling fans from Bunnings on black for our new place. I forgot to look into this before, but we have a raked ceiling and likely need an extension rod to ensure the blades clear any obstruction. Problem is, it seems the Samos is a limited supply product? I can't find anything about which rod and wiring loom is compatible. Can anyone point me towards something that is compatible? https://www.bunnings.com.au/mercator-13 ... k_p0192609 Re: Extension rod to suit Mercator Samos ceiling fans 2Sep 04, 2022 10:47 am Hey Sir snagger Welcome back I would have sent it back to the green shed, it's a lot to spend and then find out it may not be suitable after you've modified / installed it. I see eccentric loading/vibration, torque/ bearings being possible problems ... try contacting the manufacturers with a sketch, This would apply to all non standard installations. Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Extension rod to suit Mercator Samos ceiling fans 3Sep 06, 2022 9:13 am StructuralBIMGuy Hey Sir snagger Welcome back I would have sent it back to the green shed, it's a lot to spend and then find out it may not be suitable after you've modified / installed it. I see eccentric loading/vibration, torque/ bearings being possible problems ... try contacting the manufacturers with a sketch, This would apply to all non standard installations. Thanks. I'll try reach out to Mercator today. Would rather not have to return them. Re: Extension rod to suit Mercator Samos ceiling fans 4Sep 06, 2022 11:14 am Spoke with Mercator. Part number FD858900BK is the 900mm Black extension rod to suit the Samos ceiling fan. They also have a 600mm and they would both come in white as well. Spoken with Bunnings and they're sourcing a price now so that the order can be placed. Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8586 Hello Josh, This is Irving from PRIMA, we are a manufacturer of the staircase, railings, kitchen cabinets, windows, doors from China. If you have requirement to purchase… 0 5568 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6224 |
