Browse Forums Building A New House 1 Aug 25, 2022 10:52 am As my driveway and porch are on different side of the house, have to walk around to reach my front porch (alternative is go via garage space). Is it good to use concrete 1m wide , 8m2 area which costs $1200 and go with builder or can be done after handover? Is it a good idea to add a concrete layer around the house ? It sounds expensive. Any longterm benefit, or filling pebbles or stones ? Re: New Home - Concrete around house 2Aug 25, 2022 11:11 am if you are on reactive soil, you should be building a perimeter path around the entire house of at least 1M with a 50mm fall. Its handy for getting around the outside of the house, its necessary for keeping water away from the foundations. The gold standard is a strip drain at the edge of the path to collect the water run off. You can have the builder do it or you can do it after handover. After handover is usually cheaper, but if its laid poorly or incorrectly, its less likely you will get a concreter back to fix it than if it was the builders responsibility. The builder will charge you anywhere from 20-50% more to do it. Dark matter scientist, can breathe underwater, mind reader and can freeze matter just by willing it. Trust me, its in my sig. Re: New Home - Concrete around house 3Aug 25, 2022 4:35 pm I had the pour of my slab coordinated with the quite large outdoor entertaining area. Its all worked quite well. Not sure on costs - ie if it would have been cheaper to do later. But my termite boundary etc etc is all part of it. I'd personally gets as much done as possible in one hit. Re: New Home - Concrete around house 4Aug 25, 2022 6:06 pm Noname if you are on reactive soil, you should be building a perimeter path around the entire house of at least 1M with a 50mm fall. Its handy for getting around the outside of the house, its necessary for keeping water away from the foundations. The gold standard is a strip drain at the edge of the path to collect the water run off. You can have the builder do it or you can do it after handover. After handover is usually cheaper, but if its laid poorly or incorrectly, its less likely you will get a concreter back to fix it than if it was the builders responsibility. The builder will charge you anywhere from 20-50% more to do it. Thanks very much. It helps Re: New Home - Concrete around house 5Aug 31, 2022 8:03 pm Saint Mike I had the pour of my slab coordinated with the quite large outdoor entertaining area. Its all worked quite well. Not sure on costs - ie if it would have been cheaper to do later. But my termite boundary etc etc is all part of it. I'd personally gets as much done as possible in one hit. you meant the termite barrier was extended to beyond the patio? thanks Re: New Home - Concrete around house 6Sep 05, 2022 11:22 am slacker878 Saint Mike I had the pour of my slab coordinated with the quite large outdoor entertaining area. Its all worked quite well. Not sure on costs - ie if it would have been cheaper to do later. But my termite boundary etc etc is all part of it. I'd personally gets as much done as possible in one hit. you meant the termite barrier was extended to beyond the patio? thanks Yes - to the edge of the cement pour. Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 8535 You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 7078 Thanks for the photos. You need to know whether the inflow or the overflow pipe is leaking and this is a simple process of elimination. INFLOW: The vertical riser… 4 4692 |
