Browse Forums Building A New House 1 Aug 21, 2022 9:31 pm Hi All, After the render, I noticed exposed slab edges. Searching the forums, it seems exposed slab edges are normal and useful for termite management. I'm not sure, as I'm trying to find more information within VBA website. It is unsightly. Is there a possibility to make it look neater or hide it when it comes to landscaping? Thanks. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Exposed Slab Edge 2Aug 22, 2022 9:37 am That's not the slab edge but the footing The plasterers would have raked back the soil against the footings to continue the render below the ground level If you plant landscaping against a shallow footing you are just asking for trouble. You will need to get onto the external ground preparation, paving,etc ASAP or void your warranty. Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Exposed Slab Edge 3Aug 22, 2022 10:07 am Domestic slab on ground must have edge beam, edges are formed and often they are not all the way to the ground. Then you have hydrostatic pressure of wet concrete blow out building plastic below formwork edge. I have enclosed a photo from frame inspection report. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Exposed Slab Edge 4Aug 26, 2022 10:24 am ![]() That's not the slab edge but the footing The plasterers would have raked back the soil against the footings to continue the render below the ground level If you plant landscaping against a shallow footing you are just asking for trouble. You will need to get onto the external ground preparation, paving,etc ASAP or void your warranty. Thanks for your feedback. I assume it will be my builder responsibility to clean up the footing and smooth it out for the renders to continue rendering. Re: Exposed Slab Edge 5Aug 26, 2022 10:26 am ![]() Domestic slab on ground must have edge beam, edges are formed and often they are not all the way to the ground. Then you have hydrostatic pressure of wet concrete blow out building plastic below formwork edge. I have enclosed a photo from frame inspection report. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks for your feedback and photo for reference. No worries, I'll speak to my builder to cut back and tidy up the footings for our renders. Re: Exposed Slab Edge 6Aug 26, 2022 2:25 pm Don't be surprised if your builder tells you to raise the ground level to cover the bulging concrete footings and put a retaining wall on the boundary at your expense. Best to check your site plan and levels before you talk to the builder. I would have trimmed the concrete after the initial set, the fact that they haven't means the GL is to be raised... let members know how you go? my2c Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Exposed Slab Edge 7Aug 26, 2022 5:48 pm I had a similar issue where the slab edges came out past the brickwork. It was noted from my private inspector to be rectified. My builder jackhammered the overhanging concrete bits. So it's all neat and tidy now (as far as I can tell) Generally you don’t need supporting piers/blocks under garage/non-habitable floating GROUND slab (That has no load bearing structures over) if it has good soil bearing… 2 11743 Hi Courtney The mitred edges are glued up with epoxy so those little holes and gaps are areas that weren't filled correctly. Silicone is the wrong product to fill them… 2 23577 ![]() You need to refer back to the structural engineering footings and slab design for edge beams depth. The depth on reactive clay doesn’t necessarily depend only on bearing… 1 11198 |
