Browse Forums Building A New House 1 Jul 19, 2022 4:41 pm Does anyone know if the stupid rule around needing a water tank if not using gas has been rescinded in Victoria yet? Need to cut the fat on my design and if tank is not required it will have to go (toilets use bugger all water and we will not be watering gardens so not really needed). Re: Water tank requirement in Victoria 2Jul 19, 2022 11:20 pm In Victoria, a 2,000 L tank storing water from a minimum 50 sq m roof harvest area and connected to all toilet cisterns is not required if you have either: (a) Recycled water connected to the property. (b) A solar hot water heater that is gas boosted where reticulated gas is available. There was talk of allowing electric boosted solar hot water units which makes perfect sense but I don't know whether it has been introduced. I believe that heat pumps are now also an alternative but you need to confirm this. To maximise yield, you can use rainwater in the laundry and also plumb it to a HWS but you will need a well designed system that collects and supplies good quality water to the pump. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Water tank requirement in Victoria 3Jul 20, 2022 7:02 am SaveH2O In Victoria, a 2,000 L tank storing water from a minimum 50 sq m roof harvest area and connected to all toilet cisterns is not required if you have either: (a) Recycled water connected to the property. (b) A solar hot water heater that is gas boosted where reticulated gas is available. There was talk of allowing electric boosting of solar hot water units which makes perfect sense but I don't know whether it has been introduced but I believe that heat pumps are now also an alternative. You need to confirm this though. Rainwater can be used in the laundry and also plumbed to a HWS but you will need a well designed system that collects and supplies good quality water to the pump. Good luck with that. . Thanks. Yeah, they’re not being very clear on when the changes apply which is frustrating. But we’re going heat pump HWS so I might see if we can do that. Re: Water tank requirement in Victoria 4Jul 20, 2022 7:05 am Gov and council websites are frequently outdated. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Water tank requirement in Victoria 5Jul 20, 2022 8:58 am BanjoDan SaveH2O In Victoria, a 2,000 L tank storing water from a minimum 50 sq m roof harvest area and connected to all toilet cisterns is not required if you have either: (a) Recycled water connected to the property. (b) A solar hot water heater that is gas boosted where reticulated gas is available. There was talk of allowing electric boosting of solar hot water units which makes perfect sense but I don't know whether it has been introduced but I believe that heat pumps are now also an alternative. You need to confirm this though. Rainwater can be used in the laundry and also plumbed to a HWS but you will need a well designed system that collects and supplies good quality water to the pump. Good luck with that. . Thanks. Yeah, they’re not being very clear on when the changes apply which is frustrating. But we’re going heat pump HWS so I might see if we can do that. Have a good look at the rules, if I recall correctly from when I looked into it last year for it to count a heat pump HWS must be connected to 5kw or greater solar and not be able to draw from the grid at all. I ended up with a gas boosted solar system, which will be a giant waste if they ban gas in the near future, usual government incompetence. Re: Water tank requirement in Victoria 6Jul 20, 2022 9:29 am It amazes me that they don't include solar PV as an alternative. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Water tank requirement in Victoria 7Jul 20, 2022 11:46 am We're going no gas, with heat pump hot water, but need the water tank as well. It's mind boggling that they think it would be better for the environment for me to connect gas to heat hot water than the set-up we're going with. Re: Water tank requirement in Victoria 8Jul 20, 2022 11:04 pm SJT76 We're going no gas, with heat pump hot water, but need the water tank as well. It's mind boggling that they think it would be better for the environment for me to connect gas to heat hot water than the set-up we're going with. Head across to Whirpool and lookup posts from AndrewRR. He has helped people out getting approval for heat pump HWS in lieu of solar HWS. Thanks Draftroom that definitely helps a heap. We are still at the very early stage of planning to see what kind of house would fit on our plot. While we are on a… 3 15786 If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17591 Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 10896 |
