Browse Forums Building A New House Re: Retaining Wall - measure the wall by 3 surfaces???? 8Oct 23, 2008 6:35 pm mudmap If he has quoted in m2 that only refers to the face unless the wall has a return at the end in which case the returns would be measured also. So the measurement should simply be height times length. Exactly! Demolition August 2009, Construction Started September 2009, Completed December 2010 Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5179 Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16141 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6901 |
