Browse Forums Building A New House 1 Jun 24, 2022 2:03 pm Hi all. I have posted last year about my new double storey build where the entire flooring upstairs (apart from bathroom) has developed loud squeaks that can be heard loudly from below. I have taken out one of the downlight enclosures from the downstairs ceiling, and I've taken some photos. It appears that the nails that have been used to fix the subfloor (particleboard) to the floor joists have penetrated all the way through, and popped out the end - see attached photos below. Is this considered proper installation? Could this be the reason these loud squeaks have developed? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Should nails penetrate all the way through floor joists? 2Jun 24, 2022 2:12 pm not sure about the nails, however I remember my builder saying you can get the squeaks when not enough glue is applied along with the nail / screws that are used. Do you know if you had glue as well? Re: Should nails penetrate all the way through floor joists? 3Jun 24, 2022 2:19 pm sifntdaz not sure about the nails, however I remember my builder saying you can get the squeaks when not enough glue is applied along with the nail / screws that are used. Do you know if you had glue as well? Thanks for the reply. Yes, I've been told by the builder that glue was applied. But upstairs I can feel some very minor movement under my feet in certain areas (which are also the worst creaking areas), so it's possible the glue didn't hold very well. Re: Should nails penetrate all the way through floor joists? 4Jun 24, 2022 3:35 pm yesplease Hi all. I have posted last year about my new double storey build where the entire flooring upstairs (apart from bathroom) has developed loud squeaks that can be heard loudly from below. I have taken out one of the downlight enclosures from the downstairs ceiling, and I've taken some photos. It appears that the nails that have been used to fix the subfloor (particleboard) to the floor joists have penetrated all the way through, and popped out the end - see attached photos below. Is this considered proper installation? Could this be the reason these loud squeaks have developed? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The squeaking is caused by 2 things: 1. Using nails instead of screws ( the squeak is the floor moving up and down on the nail) 2. Not enough glue ( you have to use a huge amount) It is fixable by going back and screwing the boards down. Cheers Simeon Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Should nails penetrate all the way through floor joists? 5Jun 24, 2022 3:52 pm Ashington Homes The squeaking is caused by 2 things: 1. Using nails instead of screws ( the squeak is the floor moving up and down on the nail) 2. Not enough glue ( you have to use a huge amount) It is fixable by going back and screwing the boards down. Cheers Simeon Thanks for the reply. This is helpful. But does the nails going all the way through constitute improper installation? Or is this fine in practice? Re: Should nails penetrate all the way through floor joists? 6Jun 24, 2022 4:00 pm yesplease Ashington Homes The squeaking is caused by 2 things: 1. Using nails instead of screws ( the squeak is the floor moving up and down on the nail) 2. Not enough glue ( you have to use a huge amount) It is fixable by going back and screwing the boards down. Cheers Simeon Thanks for the reply. This is helpful. But does the nails going all the way through constitute improper installation? Or is this fine in practice? Nails being used at all is incorrect/improper installation If the were screws going all the way through I think that would be okay Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. 3 2999 Thanks for all replies. I just noticed now the pictures I added to post right on top of page were wrong. I attached pictures showing "current" and my "suggested" floor… 9 15140 Houses have been framed on floor joists since settlement, chipboard flooring is only around for 50 years or so, so why would it not be satisfactory? However exercise skill… 3 17755 |
