Browse Forums Building A New House 1 Jun 18, 2022 3:08 pm Hi All, Just wondering whether what you see on the attached pic (inside the red circles) is normal or is this an area of concern? I am talking about the gap between the frames and how they don't sit flush with each other. I have scheduled an inspection by an independent inspector which will happen after the entire framing is completed. If this is an area of concern I will raise it straightaway with the site supervisor as I can see this without entering the site. Thanks in advance!! u/103543_1655529174.png put the 2 draw set directly under the cooktop and the 3 draw set either side for balance 1 1397 If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 9021 DIY, Home Maintenance & Repair Are you doing this with a building permit? Conversion of a non habitable room into a habitable room requires building permit. 3 19044 |
