Browse Forums Building A New House 1 Jun 04, 2022 9:16 am Building a new 2 storey home with the lower level being rendered brick external cladding and the upper level facade being rendered blueboard. However, I am second guessing the blueboard and wondering if the more expensive hebel is the way to go. Thoughts? Re: Hebel vs Blueboard Cladding 2Jun 04, 2022 10:32 am Hey Maseeh Welcome to the forum And you will be second guessing the cost differences all the way to the bank for a loan top up. unless you own the drawings, copyright, data/proofs, costs estimates and engineering. because no one is going to provide you with that info least of all builders. They'll Tell you " It's non of your business..." and Treat you like a mushroom Who owns the drawings? Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs 1 6830 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6500 Since you are in the design stage then I would direct your questions, in writing of course, to your designer. Depending on the trust you have in the competence of your… 4 5771 |
