Browse Forums Building A New House 1 Apr 13, 2022 7:04 pm Hi there, hope anyone shed light on new home stormwater issue. The LPOD on my street kerb and no idea why need to modify stormwater system to have a detention pit. Can anyone guide me if i shall require a civil design for stormwater or just opt to builder idea below? nervous when i saw the note writing landscape and surface drain cannot be connected to the pit. The builder gave note below: Provide charged stormwater system due to inadequate fall over block to the legal point ofdischarge (LPOD) to included: 90mm painted PVC downpipes in lieu of Colorbond where connecting directly from gutter to ground level, 600mm x 600mm modification pit and exposed PVC snorkel pipe installed in front of / or adjacent to LPOD, Connection to Curb and Channel discharge point Includes a Performance Based Design Brief as a Performance Solution is required, by virtue of the theDeemed-to-satisfy installations standards being unachievable Note: Any landscaping or surface drainage will not be able to be connected to the modification pit or charged stormwater system. If the client wishes to do so, a Civil engineering design is required at the cost of the owner. This must be requested prior to contract signing so all associated costs and designs are included within the contract documentation. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Stormwater charge system to LPOD 2Apr 14, 2022 7:42 am chars0974 Hi there, hope anyone shed light on new home stormwater issue. The LPOD on my street kerb and no idea why need to modify stormwater system to have a detention pit. Can anyone guide me if i shall require a civil design for stormwater or just opt to builder idea below? nervous when i saw the note writing landscape and surface drain cannot be connected to the pit. The builder gave note below: Provide charged stormwater system due to inadequate fall over block to the legal point ofdischarge (LPOD) to included: 90mm painted PVC downpipes in lieu of Colorbond where connecting directly from gutter to ground level, 600mm x 600mm modification pit and exposed PVC snorkel pipe installed in front of / or adjacent to LPOD, Connection to Curb and Channel discharge point Includes a Performance Based Design Brief as a Performance Solution is required, by virtue of the theDeemed-to-satisfy installations standards being unachievable Note: Any landscaping or surface drainage will not be able to be connected to the modification pit or charged stormwater system. If the client wishes to do so, a Civil engineering design is required at the cost of the owner. This must be requested prior to contract signing so all associated costs and designs are included within the contract documentation. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ How is the average human supposed to understand that builder speak? So I shall try and interpret it as best as I can 1. You don't have enough fall to get your stormwater to feed to the street via gravity 2. You need a charged system which is under constant pressure, so when it rains the new water goes into the system and pushes the old or existing water in your pipes out to the street. 3.The reason you cant connect future drainage to it is that when you cut the pipe you will start with a huge fountain in your yard and end up with a system that doesn't drain water. 4. The builder is going with a performance based solution which I assume is accepted by your local council and you can happily go with their system provided they are correct. I hope this helps a tiny bit Cheers Simeon Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Stormwater charge system to LPOD 3Apr 16, 2022 1:48 pm Ashington Homes chars0974 Hi there, hope anyone shed light on new home stormwater issue. The LPOD on my street kerb and no idea why need to modify stormwater system to have a detention pit. Can anyone guide me if i shall require a civil design for stormwater or just opt to builder idea below? nervous when i saw the note writing landscape and surface drain cannot be connected to the pit. The builder gave note below: Provide charged stormwater system due to inadequate fall over block to the legal point ofdischarge (LPOD) to included: 90mm painted PVC downpipes in lieu of Colorbond where connecting directly from gutter to ground level, 600mm x 600mm modification pit and exposed PVC snorkel pipe installed in front of / or adjacent to LPOD, Connection to Curb and Channel discharge point Includes a Performance Based Design Brief as a Performance Solution is required, by virtue of the theDeemed-to-satisfy installations standards being unachievable Note: Any landscaping or surface drainage will not be able to be connected to the modification pit or charged stormwater system. If the client wishes to do so, a Civil engineering design is required at the cost of the owner. This must be requested prior to contract signing so all associated costs and designs are included within the contract documentation. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ How is the average human supposed to understand that builder speak? So I shall try and interpret it as best as I can 1. You don't have enough fall to get your stormwater to feed to the street via gravity 2. You need a charged system which is under constant pressure, so when it rains the new water goes into the system and pushes the old or existing water in your pipes out to the street. 3.The reason you cant connect future drainage to it is that when you cut the pipe you will start with a huge fountain in your yard and end up with a system that doesn't drain water. 4. The builder is going with a performance based solution which I assume is accepted by your local council and you can happily go with their system provided they are correct. I hope this helps a tiny bit Cheers Simeon Hi Simeon, Much appreciated your interpretation to human language. Per your expertise, if i choose charged system (add a pit at my front yard), will be trouble for landscaping? my backyard boundary has a sewage discharge point, can connect to that point when do landscaping or basically landscape will not require drainage but discharge on the ground? thanks in advance. Re: Stormwater charge system to LPOD 4Apr 16, 2022 1:55 pm chars0974 Ashington Homes chars0974 Hi there, hope anyone shed light on new home stormwater issue. The LPOD on my street kerb and no idea why need to modify stormwater system to have a detention pit. Can anyone guide me if i shall require a civil design for stormwater or just opt to builder idea below? nervous when i saw the note writing landscape and surface drain cannot be connected to the pit. The builder gave note below: Provide charged stormwater system due to inadequate fall over block to the legal point ofdischarge (LPOD) to included: 90mm painted PVC downpipes in lieu of Colorbond where connecting directly from gutter to ground level, 600mm x 600mm modification pit and exposed PVC snorkel pipe installed in front of / or adjacent to LPOD, Connection to Curb and Channel discharge point Includes a Performance Based Design Brief as a Performance Solution is required, by virtue of the theDeemed-to-satisfy installations standards being unachievable Note: Any landscaping or surface drainage will not be able to be connected to the modification pit or charged stormwater system. If the client wishes to do so, a Civil engineering design is required at the cost of the owner. This must be requested prior to contract signing so all associated costs and designs are included within the contract documentation. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ How is the average human supposed to understand that builder speak? So I shall try and interpret it as best as I can 1. You don't have enough fall to get your stormwater to feed to the street via gravity 2. You need a charged system which is under constant pressure, so when it rains the new water goes into the system and pushes the old or existing water in your pipes out to the street. 3.The reason you cant connect future drainage to it is that when you cut the pipe you will start with a huge fountain in your yard and end up with a system that doesn't drain water. 4. The builder is going with a performance based solution which I assume is accepted by your local council and you can happily go with their system provided they are correct. I hope this helps a tiny bit Cheers Simeon Hi Simeon, Much appreciated your interpretation to human language. Per your expertise, if i choose charged system (add a pit at my front yard), will be trouble for landscaping? my backyard boundary has a sewage discharge point, can connect to that point when do landscaping or basically landscape will not require drainage but discharge on the ground? thanks in advance. Hi Chars0974 I am sitting on site at North Ryde watching an excavator dig my footings, so if you have 5 mins give me a call and I shall explain what I think you should do Ph 0431 712 792 Cheers Simeon Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Stormwater charge system to LPOD 5Aug 21, 2022 7:47 pm Hi Simeon, I am in a similar situation - what did you suggest for chars0974? builder suggested filling up the plot ~ 0.5m to achieve gravity drainage? thanks Re: Stormwater charge system to LPOD 6Aug 22, 2022 6:18 pm slacker878 Hi Simeon, I am in a similar situation - what did you suggest for chars0974? builder suggested filling up the plot ~ 0.5m to achieve gravity drainage? thanks Are you allowed to do that in QLD? In Sydney each council has different stormwater policies and what you can do in one you cant do it another. For single dwellings if your house falls away from the street you have 3 options: 1. Get an easement over a neighbour's property 2. Use a charged system 3. Use an absorption pit/trench Happy to talk you through it if you call me tomorrow. Number is 0431 712 792 Cheers Simeon Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Stormwater charge system to LPOD 7Aug 22, 2022 6:36 pm chars0974 my backyard boundary has a sewage discharge point, can connect to that point when do landscaping or basically landscape will not require drainage but discharge on the ground? Sounds like chars was thinking of plumbing surface drainage to sewer. I hope not! 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Stormwater charge system to LPOD 8Aug 23, 2022 5:32 am SaveH2O chars0974 my backyard boundary has a sewage discharge point, can connect to that point when do landscaping or basically landscape will not require drainage but discharge on the ground? Sounds like chars was thinking of plumbing surface drainage to sewer. I hope not! he was! I forgot to mention that thanks for the reminder Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. If you already have a contract, is the inspection cost stated in there? If not they would be forced to issue you a variation which you could of course object to. 12 25870 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4872 Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 8481 |
