Browse Forums Building A New House 1 Mar 25, 2022 6:20 am What happens when builder attempts to fix defects during warranty period but makes matters worse or rectification is still to a poor quality of workmanship? What can I do if I’m losing faith in the rectification works, ie builder’s ability to fix. What’s the average number of defects noted by others during warranty period? Is it normal to note hundreds? Re: Fixing defective building work 2Mar 25, 2022 1:06 pm It depends on the type of defect, if it is Major or Minor. I would suggest get a copy of Standards & Tolerance Guide issued by Fair Trading, have a good read through, understand the viewing positions! and natural light. Go through the home dot them all, then detail them on a list. Send the list to the builder advising these are all the outstanding defects, that you are willing to have an inspection with the builder to walk through and review them all but then you require them to be rectified within 14 days of the inspection or if no inspection 14 day of receipt of this list, otherwise you will lodge a complaint with fair trading and will follow through to NCAT. The other part of your question "What’s the average number of defects noted by others during warranty period?, "How long is a piece of string." I do PC inspections for a number of builders as well as clients, the builders use me as a clean set of eyes and as part of there QA plus they hand my unedited report to the owner after using it as part of the PC walk through. The last one was a high end reno $2.5m, the report was 102 pages, major defects "Zero" minor defects as defined under Standards & Tolerance 300'ish. Please don't get me wrong the quality was very high. The items consisted of paint runs, drips, splatters on hardware, silicon not being tooled off, over runs of paint, plus other stuff. This builder had gone through the house numerous times but after awhile you start not seeing the forest for the trees, hence why he uses me. A defect is not always sloppy or poor workmanship, it can be something that has happened after or wasn't finished and forgotten. That your builder is coming back is good, that's half the battle. I would judge the builder on the quality of his finished work. We are Expert Consultant's, and we are here to help. Re: Fixing defective building work 3Mar 29, 2022 12:47 am They’ve been really really slow with getting through the defects and the quality of the finished work is pretty poor, the number of times someone has attempted to fix something only to create further problems and more defects to the point where we don’t want trades back. And I’m sitting here thinking this can’t just be happening to me so wondered if there are others out there who’ve had a similar experience. Re: Fixing defective building work 4Mar 29, 2022 8:44 am Building2021 They’ve been really really slow with getting through the defects and the quality of the finished work is pretty poor, the number of times someone has attempted to fix something only to create further problems and more defects to the point where we don’t want trades back. And I’m sitting here thinking this can’t just be happening to me so wondered if there are others out there who’ve had a similar experience. as mentioned, understand the guide to standards and tolerances. most of it is favourable,, but some peope with exacting standards can feel let down by some of it. In the end it does sound like the builder cant be bothered fixing stuff. Its at this point that you're eating into their margin. It shouldn't be like that, but often is. Dark matter scientist, can breathe underwater, mind reader and can freeze matter just by willing it. Trust me, its in my sig. Re: Fixing defective building work 5May 05, 2022 5:50 pm Building2021 What happens when builder attempts to fix defects during warranty period but makes matters worse or rectification is still to a poor quality of workmanship? What can I do if I’m losing faith in the rectification works, ie builder’s ability to fix. What’s the average number of defects noted by others during warranty period? Is it normal to note hundreds? Hi Building2021 Unfortunately, defects are a common occurrence in home building in NSW. A 2019 research published by Deakin University and Griffith University highlights 212 building defect reports from NSW, QLD and VIC. You can look into getting a building expert to assess the defects. A builder is required to rectify defects until they’re fixed or until the builder compensates you for their damages. You may contact a specialist construction lawyer who can work with you and a building expert, and assist you in dispute resolution, if it comes to that. Or you can go straight to Fair Trading with your matter. Cheers John Get sound legal advice. We manage Building Disputes, Construction Contracts, Security of Payment. PM for queries. https://www.contractsspecialist.com.au/articles/ Thank you @ashington Homes for your reply! They just got back to me and offered credit for me to just take it as is. It was a less than quotes I got from ceiling… 6 1991 I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9938 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 5098 |
