Browse Forums Building A New House 1 Mar 13, 2022 3:12 pm Hi all I have heard that this is the BEST place to do to with the helpful community here. I do need some advice on FSR. We are building our first home and getting conflicting information from different builders. We are trying to maximise our FSR, so checking -in if the staircase is included in the calculation. We are doing a U-shaped design and that seems to take 9sq metres, making our livable areas such as living and dining really tiny. Grateful if anyone can assist with this. Is there any document which spells this out? Also, if you have any knowledge on what is to be excluded in the computation. We will be going through CDC instead of council as CDC has a better FSR compared to the 0.55 with Campbelltown Council. Thank you. Re: FSR under CDC 3Jan 29, 2023 11:56 am HA_IP Hi, Did you find any answer - i have similar situation in Parramatta Council with FSR0.5 Under CDC, the stair void for the 2nd story in excluded but the area of the stairs on the ground floor is included. Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: FSR under CDC 4Jan 30, 2023 4:00 pm Ashington Homes HA_IP Hi, Did you find any answer - i have similar situation in Parramatta Council with FSR0.5 Under CDC, the stair void for the 2nd story in excluded but the area of the stairs on the ground floor is included. I called Parramatta council today and they confused me even more saying, since I am in the part which used to be under Hornsby LEP, I need to check Hornsby DCP, which doesn't have any FSR but GFA Any idea how GFA 430sqm is defined? Does it include 60sqm Granny ? then my Main building getting smaller & smaller on a 900+sqm lot, it's such a shame Re: FSR under CDC 5Jan 31, 2023 11:18 am Hi HA_IP, I'm currently building in the Hornsby Shire under CDC, and yep, the staircase area is included in ground floor space calculations and excluded as a void in the upper level. I too have an existing granny flat on my property and the site coverage calculations for my build had to take the existing granny flat into consideration from a site coverage and GFA perspective. I've got a 1062 sqm block and was able to build a house 384 sqm (<> 41.5 squares) in size. Happy to share the GFA details via private message. Re: FSR under CDC 6Jan 31, 2023 1:23 pm KnockItDown Hi HA_IP, ... Happy to share the GFA details via private message. Thanks a lot that would be very useful. I was about to start Granny but now if I deduct 60sqm Granny + 20sqm covered alfresco from 430sqm my Main will be left with only 370sqm or 350sqm? under Hornsby DCP And to maximize my Main Floor area what kind of strategy we can use? like add more Void on upper floor, detach Garage ? The rules related to 'Attached' space not being excluded is also another concern. https://legislation.nsw.gov.au/view/htm ... ch.1-sec.4 *********************************************** Re: FSR under CDC 7Feb 19, 2023 11:19 pm Ashington Homes HA_IP Hi, Did you find any answer - i have similar situation in Parramatta Council with FSR0.5 Under CDC, the stair void for the 2nd story in excluded but the area of the stairs on the ground floor is included. are you able to clarify if that is also applicable under DA? I'm looking at pursuing under DA due to being in a Flood planning area and wonder whether the stairs for ground and upper level are excluded from FSR under DA. Re: FSR under CDC 8Feb 20, 2023 6:37 am marialerobinson Ashington Homes HA_IP Hi, Did you find any answer - i have similar situation in Parramatta Council with FSR0.5 Under CDC, the stair void for the 2nd story in excluded but the area of the stairs on the ground floor is included. are you able to clarify if that is also applicable under DA? I'm looking at pursuing under DA due to being in a Flood planning area and wonder whether the stairs for ground and upper level are excluded from FSR under DA. It really depends on which council you are in as some have different interpretations. Also, just because you are in a flood zone doesnt necessarily mean you cant go CDC, I have two currently in flood zones that we have CDC approval on. Happy for you to PM me with details and I can take a look Cheers Simeon Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. I want to build a bigger driveway (without a nature strip) than has been approved under my CDC. I’ve also had a DA approved to build a deck. It looks like I can do this… 0 4849 you need to make an application to your local council for this as they are the approval authority for driveways cheers Simeon 1 7101 Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 8537 |
