Browse Forums Building A New House 1 Feb 26, 2022 9:57 am Anyone has experience with builder having difficulty obtaining a certificate of occupancy? Builder told us a drainage plumber whom they have engaged at the initial stages of our build completed the work but now refused to issue a compliance certificate. They have had various issue with his work ethics and have since parted ways. Apparently the work had been done properly and our independent inspector did not raise any issue with drainage so far. Builder has now lodge a complaint with VBA but has been advised that the process will take weeks or months. The build (in Melbourne) is now complete but we can't move in because of this. Very frustrating!!! Re: Plumber not issuing certificate of compliance 2Feb 26, 2022 3:44 pm The VBA should have been notified without delay. How do you know the plumbing has been done properly? A private building consultant who does stage inspections wouldn't know. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Plumber not issuing certificate of compliance 3Feb 26, 2022 5:52 pm [quote="SaveH2O"]The VBA should have been notified without delay. How do you know the plumbing has been done properly? Yeah, we have no way to know for sure except for reassurance from the builder. Not sure what to do now.... Re: Plumber not issuing certificate of compliance 4Feb 26, 2022 8:43 pm The VBA (Matthew Guy's legacy) isn't the most efficient body to deal with but it wouldn't hurt to contact them and state yoour position and the urgency. Refusing to supply a Certificaye of Compliance is not looked on lighly. The only way to know whether the drain (sewer) and stormwater pipes are compliant and sound is to have a CCTV inspection by a good plumber. It is something that all new houses should have pre handover anyway. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. I can totally relate to your shed project struggles—I recently tackled a similar ordeal, and it was quite the journey. Navigating through all those regulations and hoops… 4 7439 From a pure legal perspective, if you've signed the variation, it is a very high bar to have it set aside. No-one can give you legal advice on a forum, but you would need… 3 5573 |
