Browse Forums Building A New House 1 Feb 21, 2022 9:52 pm Hi, Help please!! I have zerobound cladding walls on 2 side of my house. 1 side has been installed as per zerobound guidelines. The otherside has been just slapped up without following guidelines. There is gaps, broken parts throughout it. If it is not installed as per guidelines then it is not fireproof/waterproof. Builder is saying he will cork it up, but its completely installed wrong. Nails have been used instead of screws. Panels are already lifting off this wall, nails are sliding out of walls. As it is not installed right, there would be no product warranty. I'm building on a zero boundary lot with neighbors house against mine. I'm disputing with Builder at the moment to get it all replaced and installed as per product guidelines. My site supervisor makes all the excuses in the world. Only yesterday the wrong bricks were delivered to my site. What would be the next steps if site supervisor won't listen? I'm not risking my families safety. Once the neighbors wall is up this would all be hidden so I only have a few weeks at most. Thank you all Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Zerobound cladding installed wrong -help 2Feb 21, 2022 10:00 pm Track down the construction /engineering cross section detail for the Boundary wall contact the Council building department and ask to speak to a building surveyor about fire rating Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Zerobound cladding installed wrong -help 3Feb 21, 2022 10:05 pm StructuralBIMGuy Track down the construction /engineering cross section detail for the Boundary wall contact the Council building department and ask to speak to a building surveyor about fire rating Cheers Chris Thank you for the reply and information. Hopefully they will just re-do the job correctly but with how building costs are going and the fact this house is a year behind doubting they will. Thanks heaps Re: Zerobound cladding installed wrong -help 4Feb 21, 2022 10:12 pm StructuralBIMGuy Track down the construction /engineering cross section detail for the Boundary wall contact the Council building department and ask to speak to a building surveyor about fire rating Cheers Chris Sorry to ask another question, do you know if cladding gets inspected at frame stage? Builder has inspection booked tomorrow. Then i will have my own private inspector go over it all too. Re: Zerobound cladding installed wrong -help 6Mar 03, 2022 5:34 pm StructuralBIMGuy Track down the construction /engineering cross section detail for the Boundary wall contact the Council building department and ask to speak to a building surveyor about fire rating Cheers Chris My private inspector has marked the wall as a major defect was excessive gaps and broken panels needing repairs Site supervisor said he past on report to carpenters to address. I rock up tonight and neighbors brick wall has gone up without repair my wall. In for a fight now to get major defect walls repaired before other neighbors wall goes up. Going to call council in morning, as this is a zerobound fore cladding wall. The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 16145 2 31712 there is only 20% difference in concrete strength between 20 mpa and 25 mpa, so check with your engineer first if it fits his calculation tolerances. There are ways to… 6 18542 |
