Browse Forums Building A New House 1 Feb 18, 2022 1:43 pm Hi everyone! First time poster here - we recently finished construction of our new house and have been living here for approx 8 months. The lot next to us will shortly commence construction and are building 200mm from our shared boundary (garage wall). Can this be done without gaining access to my property? The builder has stated that they will be in touch should they require access but I'm not keen on having the fence pulled down for a number of months whilst they build (for obvious security and privacy reasons). It'd obviously be tight when it comes to laying bricks, right? We also paid for the cost of the entire fence as the lot has only recently changed hands from the developer (who wouldn't contribute). Re: Access to neighbouring property - building on boundary ( 2Feb 18, 2022 2:30 pm not really, to lay neatly, best give them access. If the fence is colorbond it can be taken down and reinstated after without damage. Just ask them to turf/ landscape any damage and erect a temp fence for security and contribute half original cost. Re: Access to neighbouring property - building on boundary ( 3Feb 18, 2022 2:33 pm I think they would still need to pull down part of the fence to put down the formwork for the slab. They might need access to make the brick joints look nice, even if they can lay them from the inside. You can ask them to rotate the part of the fence they will be pulling down towards your wall to close off the backyard. Would be also good opportunity to ask them for the 50% contribution I'll probably be in the same position as your neighbors when we finally start building, cause the houses around our lot are already going up, but our builder won't commence construction for a while. Re: Access to neighbouring property - building on boundary ( 4Feb 19, 2022 8:35 pm You will find they will do whatever they can get away with to make job easier (supervisor, concretor, carpenter, bricky etc) They will know your movements and put a plan to get in do what’s required. Make sure up a 6am, water the garden, show bit of activity, look at fence, Re: Access to neighbouring property - building on boundary ( 5Feb 23, 2022 9:34 am We were in a similar situation in our current house. The builder next door didn't remove the fence, or approach us or anything. I came home from work one day, and they had instead laid the bricks on the boundary wall from inside the frame. The tiny gap between their brick wall and the fence shows a hot mess (bits of mortar everywhere, bricks didn't get cleaned etc.), and the fence is starting to lean toward our place. Re: Access to neighbouring property - building on boundary ( 6Feb 23, 2022 10:50 am mcbks We were in a similar situation in our current house. The builder next door didn't remove the fence, or approach us or anything. I came home from work one day, and they had instead laid the bricks on the boundary wall from inside the frame. The tiny gap between their brick wall and the fence shows a hot mess (bits of mortar everywhere, bricks didn't get cleaned etc.), and the fence is starting to lean toward our place. Curious, did they also pour the slab without removing the fence, or was it done before the fence went in? Re: Access to neighbouring property - building on boundary ( 7Feb 23, 2022 10:58 am strannik mcbks We were in a similar situation in our current house. The builder next door didn't remove the fence, or approach us or anything. I came home from work one day, and they had instead laid the bricks on the boundary wall from inside the frame. The tiny gap between their brick wall and the fence shows a hot mess (bits of mortar everywhere, bricks didn't get cleaned etc.), and the fence is starting to lean toward our place. Curious, did they also pour the slab without removing the fence, or was it done before the fence went in? They did the whole lot without removing the fence. Nobody approached us about anything, so had no idea that wasn't the norm until I saw how awful the bricks looked in the gap. Whether or not they asked our landlord and they said no, I'm not sure. Our relationship with the owner is good, but I'm not sure if I want to impose putting a pole on their property. Your conversation with your neighbour must have gone well… 4 9976 For reference, this is the Austlii reference. My take on this is, that they would be breaking the law denying access to a homeowner in Victoria, or their agent from having… 1 9587 You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17454 |
