what is the height of the top of the window if you have a 3.2m ceiling to look good.
Is that 2.9m or 2.6m? or?
Browse Forums Building A New House Re: 3.2m ceiling and the height of the top of the window 2Jan 14, 2022 9:56 am There are two things to consider with appearance: Inside view: I always think the closer to the ceiling of the window head, the classier it looks. Outside view: What is the builder going to do over the window. . . . see this link https://anewhouse.com.au/2022/01/what-a ... w-infills/ The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10682 Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31263 Thanks Ardo, they are sort of semi concealed. I think it is only a few millimetres. I see if they can adjust the hinges. 4 3796 |
