alfresco above ground
or 2 steps down at the middle of the house and have a more reasonable alfresco height (ie: ~0.8m). Has anyone have similar experience, which one did/will you choose?
Wasn't cheap but it basically it gives us a continuous level between the downstairs living area, alfresco, pool and yard.
We had about the same drop, and put 3/4 of it on the split which we integrated with the main staircase, because I hate seeing steps between living areas.
do u have alfresco height of 80cm or pretty much level to the ground. if 80cm I am wondering do you put a fence around that for safety and big step down to the yard, currently it requires around 3 to 4 steps down the yard
We had it about 20-30cm from the ground.
Thanks Boris
Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m…
13/08/2023
Hi, I'm new to this forum so I hope I'm doing this post correctly. Please advise if it's not. I've just bought my place. The inground pool has a marble lining that has…
