Browse Forums Building A New House 1 Jan 03, 2022 10:51 am I understand that its difficult to keep a good finish on painted glass when it gets allot of sun - especially when the glass is patterned. I've come accross a few primer / protector products that may or may not work.Has anybody used any of these on glass? 1. https://www.swiftsupplies.com.au/weicon ... -250ml-can 2. https://www.cmcpaints.com.au/shop/1k-glass-primer/gp. 3. https://www.nanovations.com.au/product- ... ample.html. 4. https://www.automegastore.com.au/303-ae ... VhEALw_wcB. 5. https://www.fixtech.com.au/primers---ac ... eaner.html Re: Painting window glass 2Jan 03, 2022 12:28 pm I used ESP many years ago, I can't remember the purpose but I remember being pleased with it. 3in1 Supadiverta. Rainwater Harvesting Best Practice using siphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost, siphonic, eaves gutter overflow solution. Re: Painting window glass 4Jan 03, 2022 10:03 pm Hmmm, the ESP was a primer I used on glass to make the paint better adhere to the glass. I think I have mixed up what you actually need. Sorry. 3in1 Supadiverta. Rainwater Harvesting Best Practice using siphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost, siphonic, eaves gutter overflow solution. Re: Painting window glass 5Jan 04, 2022 12:21 pm ![]() Hmmm, the ESP was a primer I used on glass to make the paint better adhere to the glass. I think I have mixed up what you actually need. Sorry. No, I just need ways to make the job last.nI will definately be using your seggestion as a primer. ![]() Hi all, Would appreciate some advice on how to clean up the paint job around this window frame. The frame extends across the width of the room and joins straight up to… 0 82139 just get it quoted by your window supplier. The frame opening is the same so it makes no difference in design stage. The savings on glass means more framing and labour.… 1 24266 |
