Browse Forums Building A New House 1 Dec 16, 2021 7:21 pm Hi, we are at prelining stage after 6 months of frame being exposed to weather. We had our first walkthrough on site yesterday and noticed that many of the window frame reveals had cracking. See attached photos. Is this anything to worry about? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Window frame reveal cracked at prelining stage 3Dec 16, 2021 8:20 pm ![]() yep need to be replaced, looks like mdf which can’t get wet without swelling and splitting Thanks Pulse. We checked with supervisor and he said they are MDF and will be repaired at next stage and not to worry about it. Also had a private inspector do prelining inspection and he thought they were pine (not MDF) and said not to worry about it. Inspector said it’s complex to replace now because bricks are done and if replacing will have to replace flashing etc. which according to him is not a good idea to do now. Is this true? Or do builders normally replace reveals after brickwork is done? Re: Window frame reveal cracked at prelining stage 5Dec 17, 2021 9:18 am ![]() Also do you know what is the risk if we don’t replace these? they get worse Dark matter scientist, can breathe underwater, mind reader and can freeze matter just by willing it. Trust me, its in my sig. Re: Window frame reveal cracked at prelining stage 7Dec 17, 2021 1:28 pm ![]() ![]() ![]() Also do you know what is the risk if we don’t replace these? they get worse Thanks Noname. Is it possible to replace reveals after brickwork is completed? sure, but you want to get to it before the arcs go on Dark matter scientist, can breathe underwater, mind reader and can freeze matter just by willing it. Trust me, its in my sig. Re: Window frame reveal cracked at prelining stage 8Dec 17, 2021 1:34 pm ![]() ![]() yep need to be replaced, looks like mdf which can’t get wet without swelling and splitting Thanks Pulse. We checked with supervisor and he said they are MDF and will be repaired at next stage and not to worry about it. Also had a private inspector do prelining inspection and he thought they were pine (not MDF) and said not to worry about it. Inspector said it’s complex to replace now because bricks are done and if replacing will have to replace flashing etc. which according to him is not a good idea to do now. Is this true? Or do builders normally replace reveals after brickwork is done? Hi Kingpin In my opinion those windows need to be removed and sent back to the factory to be fixed. I don't know if this applies in your case, but the common issue is that builders order the windows too early and they sit in the weather. I told this story a while ago that I was visiting the Wideline Window factory on central coast of NSW and they have a section in their yard of approx 400sqm dedicated to fixing windows that are sent back from building sites. Removing a window and replacing a window flashing is a pretty basic process in building terms and frankly, you need to stand your ground on this one. I strongly disagree with your inspector as even if they are difficult to remove in your case, that shouldn't be an excuse for giving you a substandard product. You are paying for a brand new home not a defective 2nd hand one. All the best Simeon Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Window frame reveal cracked at prelining stage 9Dec 17, 2021 1:45 pm second everything that Simeon said, MDF reveals are a bad idea IMHO, I’m no expert but people put glasses of water down in humid weather on the window sill and condensation in cold climates can cause them to swell as the aluminium frame will condense. They can be patched now but not fixed like new. Pine is better. I’d insist on fixing them. How much roughly does a custom builder charge plaster reveal for windows for new houses. Alternatively, how much would it cost to get architrave removed and plasters… 0 7866 I've gone for pre-fab walls. I did it because I wanted to remove the idiot factor from the construction on site , control theft and reduce waste plus its supposed to be… 10 42304 how on earth did that happen? the tiles need to be replaced, I’d be checking the concrete slab too, either tile needs to be loose or the slab cracked I would think 1 10025 |
