Browse Forums Building A New House 1 Dec 01, 2021 2:34 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Please help! Building a new home in NSW. Bathroom to be tiled and main floor laminated timber. Once Tile is completed it will be 50mm higher than the slab due to bedding for tiles. Once laminated floor is completed it will be 12mm higher than the slab. This will make the bathroom floor 38mm higher than the main floor. I am concern with the height difference and I see this is a safely concern.(very likely to stumble as pictured) Ideally the wet area should have been 40-50mm lower when the slab was made to compensate the bedding for tiles. I want the difference as less as possible (not more than 10mm) What is acceptable height in building standard? Can I hold my builder responsible to fix it? What are my options? Please help , many thanks. Mohh. Re: Bathroom floor much higher than main floor 4Dec 02, 2021 8:04 am Mohh Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Please help! Building a new home in NSW. Bathroom to be tiled and main floor laminated timber. Once Tile is completed it will be 50mm higher than the slab due to bedding for tiles. Once laminated floor is completed it will be 12mm higher than the slab. This will make the bathroom floor 38mm higher than the main floor. I am concern with the height difference and I see this is a safely concern.(very likely to stumble as pictured) Ideally the wet area should have been 40-50mm lower when the slab was made to compensate the bedding for tiles. I want the difference as less as possible (not more than 10mm) What is acceptable height in building standard? Can I hold my builder responsible to fix it? What are my options? Please help , many thanks. Mohh. Hi Mohh So, you need to have a look at your engineering plans and your construction contract to see whether or not the rebate in the slab was specified. If it was on the drawings and or in the contract specification schedule then yes you can hold your builder accountable. The only way to really fix it now would be to screed the rest of your floor where the laminate is going. Allow $40/sqm for that. Problem is you will lose some ceiling height. Otherwise you are pulling your slab up and starting from scratch. All the best Simeon Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Bathroom floor much higher than main floor 5Dec 02, 2021 8:40 am If they couldn't get the ffls levels correct A further question that begs to be answered Did they get the footing correct for masonry walls? Best to have it properly inspected and possibly recertified. Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Bathroom floor much higher than main floor 6Dec 02, 2021 6:24 pm Can't they just shave off part of that to make a smooth transition? We also have a level difference between bathroom floors and the adjacent area, but the way they managed the transition is to make a slope with the tile over it. Re: Bathroom floor much higher than main floor 7Feb 24, 2022 11:15 am Mohh Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Please help! Building a new home in NSW. Bathroom to be tiled and main floor laminated timber. Once Tile is completed it will be 50mm higher than the slab due to bedding for tiles. Once laminated floor is completed it will be 12mm higher than the slab. This will make the bathroom floor 38mm higher than the main floor. I am concern with the height difference and I see this is a safely concern.(very likely to stumble as pictured) Ideally the wet area should have been 40-50mm lower when the slab was made to compensate the bedding for tiles. I want the difference as less as possible (not more than 10mm) What is acceptable height in building standard? Can I hold my builder responsible to fix it? What are my options? Please help , many thanks. Mohh. Hi Mohh One option is to have the property looked at by a building expert. The Master Builder Association has a list of building experts you can check out. If you happen to be in Melbourne, you might want to get in touch with Building-Expert Cheers John Get sound legal advice. We manage Building Disputes, Construction Contracts, Security of Payment. PM for queries. https://www.contractsspecialist.com.au/articles/ interesting situation what happened after builder issued final invoice? did you list as defect or not does the building surveyor have any responsibility? ie. issuing… 13 46972 4 10824 The warning is on the sticker on the door too. Second the aluminium powdercoat 6 18204 |
