Browse Forums Building A New House 1 Nov 23, 2021 12:13 pm i need a solution for this as i donot want to push my garage back or house back otherwise there will be no space at the back side. "For this lot, our engineer has fud that what you are wanting the front setback to be won’t work with the driveway grade As per the attached photos, the driveway falls 1m very steeply. To have the garage on setback 5.5m we wont achieve the allowable driveway grade. The house will need to be pushed back. Pushing the garage back alone wont be enough either as the portico sticks out too far at the front and you cant have a driveway higher than the portico." Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for… 4 4549 If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with… 3 8324 Hi All It has been a few weeks since my last update. The build has been progressing well. No major issues to report. The scaffolding was dropped today, gyprock will be… 96 357116 |
