Browse Forums Building A New House 1 Nov 08, 2021 10:35 am Hi, My house is still under construction. It's built on stumps and bearers, and enclosed with bricks. I took these photos last week. There is a pool of water and mud. I guess it was raining before floors were constructed. This is just under one section of the house I can still see now, not sure if there is any other pool of water somewhere else. My land is flat, I don't imagine the water can flow to anywhere. More importantly, all bricks are already up for ground floor. I would say that the water is trapped. Is this a concern? Will I have moisture and smell issues later on? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Water under sub floor, normal? 2Nov 09, 2021 8:06 am No it is not normal. Your house does not comply with NCC code. Why isn't your independent inspector advising you on that issue? NCC-2-16 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Your foundation material may be ruined, dampness will create conditions for toxic mould and termite infestation Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28813 Thanks for your advice. So far i have not noticed any issues with doors and windows. Builder advised they will organise drainers to inspect 2 weeks ago but no further… 7 18792 |
