Browse Forums Building A New House Re: The minimum distance between FFL and natural ground? 3Oct 28, 2021 8:10 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: The minimum distance between FFL and natural ground? 5Oct 28, 2021 8:22 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: The minimum distance between FFL and natural ground? 7Oct 28, 2021 8:31 am Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: The minimum distance between FFL and natural ground? 8Oct 28, 2021 8:38 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: The minimum distance between FFL and natural ground? 10Oct 28, 2021 8:44 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: The minimum distance between FFL and natural ground? 15Oct 28, 2021 10:07 am Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: The minimum distance between FFL and natural ground? 19Oct 28, 2021 8:45 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: The minimum distance between FFL and natural ground? 20Oct 29, 2021 4:55 am Chess Hi guys, I am at the planning stage of house siting. The builder advised 0.8m cutting at the rear which will cause retaining wall later. We want to increase by filling and dropped edge beam instead to keep the existing retaining wall. However we can't make decision on how much to fill since we don't know: How much is the minimum distance the finished ground lever should be higher than the outside natural ground level. Below amendments are based on increasing the RL (Is RL same with FFL?) from builder's proposal by 0.4m. The only area is slightly lower than natural ground is alfresco. Can anyone provide advice how much we need to increase the house based on their plan? 0.4m or 0.5m? To make sure: 1. The finished level is still higher enough to keep the slab safe from the rain. 2. Existing retaining wall can be kept so no more $$ on retaining wall. Thank you. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Happy Friday Chess I am struggling to follow what you are trying to do. I know it has something to do with a retaining wall at the rear and you are worried about water. I am worried about your driveway being too steep at the crossover and council rejecting it as you wont be able to get your ferrari in without scraping it I am finding it hard to read your plans the way the system uploads. Just give me a call and I'll try and work it out for you. My number is 0431712792 Cheers Simeon Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. I am looking to design an entry door to a lower ground basement that has 2200mm between the external entry height to FFL of the ground floor. This door will provide an… 0 11370 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6711 My land is 260m2 (10m x 26m) located in claymore NSW. Under campbelltown council. I know in general the following setbacks would apply ground floor side setback =… 0 6931 |
