Browse Forums Building A New House Re: Hebel or wood frame 3Oct 04, 2021 2:38 pm Steel and timber framed homes require Cladding Brick and concrete do not Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Hebel or wood frame 4Oct 05, 2021 7:10 am annaHome Does anyone know if it’s best to build with wood or steel frame for a new build ? Hi annaHome, Both do the same job. Timber is far more expensive at the moment, so if I were building my own house right now I would definitely be using steel. If you have the budget, double brick is now almost on par with Brick veneer when using a timber frame. But it really comes down to your budget and you are trying to achieve out of your home. all the best with your choice and build Simeon Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Hebel or wood frame 5Oct 06, 2021 3:58 pm alexp79 Best to build frameless Do you mean best to build double brick ? I really like a floor plan for a volume builder and they use steel frame and Hebel. I have never heard of Hebel but apparently Scandinavia use it since 70 years ago. It’s just that this builder cannot do double brick Re: Hebel or wood frame 6Oct 06, 2021 9:56 pm Cladding requires a frame Here's Lightweight Aerated cladding with vertical cracks Make up your own mind Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Hebel or wood frame 7Oct 06, 2021 10:10 pm annaHome alexp79 Best to build frameless Do you mean best to build double brick ? I really like a floor plan for a volume builder and they use steel frame and Hebel. I have never heard of Hebel but apparently Scandinavia use it since 70 years ago. It’s just that this builder cannot do double brick double brick, full brick, concrete, icf, Hebel blocks are all examples of frameless construction brick veneer, Hebel panels, rendered EPS, etc. are examples of cladding to a frame (which can be steel or timber) This is 100% true. You can not hang anything on steel frames. very frustrating 8 8062 I was looking at different options for a fence for my build and Hebel PowerFence seemed like a good option (one of the criteria was a solid wall look). However, I don't… 0 5906 1 6638 |
