Browse Forums Building A New House 1 Sep 27, 2021 2:18 pm Hi All, Builder is providing below hot water system but I need your advice. Hot Water Unit (Solar Gas) - Chromagen 9202VOBP11T2608 Tank with (2No.) Chromagen CR110-BP11 Solar Panels Is it better to go with Tankless Continuous Flow Heaters (Rinnai 26L ) just one system? the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14049 I’d go heat pump, efficient and you can have a large storage tank so you don’t run out. If the house is big it can take a while for the water to run hot. I was lucky… 1 482 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20231 |
