Browse Forums Building A New House 1 Sep 27, 2021 10:18 am Hi all.... 22.5 or 26.5 degree roof pitch? Which looks good?.. Ours is 37 squares home - 11.5 frontage and 17m wide. Builder would provide 22.5 as standard. If possible if you can share some pics with me for comparison, will be much helpful. Thanks! Façade pic attached Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Roof pitch 2Sep 27, 2021 12:50 pm The extra 4% pitch calc will affect your roof drainage calcs for wind driven rain. You first need to ask your builder whether it would result in either having an additional DP at the front (if one is not already on the plan) or a larger gutter. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Why don't you call and talk with someone at the town planning in your council? 1 2180 Hello! I've alfresco pitch of 3 degrees sitting just below the highlight window. Need advice on below: 1. Will the 3 degree pitch be ok to drain the rain water? The roof… 0 4194 2 9447 |
