Browse Forums Building A New House 1 Sep 25, 2021 6:00 pm I’m considering doing a KDR but my lot is an odd one. It’s at the end of a T- cul de sac and the block is 40.5m wide but only 18.5m long however only the first 15m of the width is the front yard (see pic for better explanation) From my local council website it looks like my required setbacks are 5.5m from front and 0.9m from side but with my lot I believe the rear is technically viewed as a side boundary as the house is currently only 1.8m from the back fence. Really struggling to find anything that would suit and not even sure if I could just put a narrow lot house sideways on it as I’ve seen this done on nearby houses with the same shaped block Can anyone suggest any big builders I don’t really want to go with a custom build Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Wide shallow house designs 2Sep 27, 2021 5:02 am Aliidra I’m considering doing a KDR but my lot is an odd one. It’s at the end of a T- cul de sac and the block is 40.5m wide but only 18.5m long however only the first 15m of the width is the front yard (see pic for better explanation) From my local council website it looks like my required setbacks are 5.5m from front and 0.9m from side but with my lot I believe the rear is technically viewed as a side boundary as the house is currently only 1.8m from the back fence. Really struggling to find anything that would suit and not even sure if I could just put a narrow lot house sideways on it as I’ve seen this done on nearby houses with the same shaped block Can anyone suggest any big builders I don’t really want to go with a custom build Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi Aliidra My very first house I built ( well Clarendon built for me in 2004/2005) was on a site almost identical to yours. Google it - 19 Lorraine Ave Padstow Heights. You will see from the aerial that the garage had to be twisted and oriented towards the road. A bit odd but it worked. It recently sold so here is a a link and you can see the floor plan - https://www.realestate.com.au/sold/prop ... -136504558 The reason I mention this is that I see from your posts that you seem to like the Clarendon designs. I know the owners of Clarendon extremely well and from a project home perspective they would be a good choice for you. If you like I can make an introduction and see if they can appoint someone to adapt one of their designs to your site like they did with mine. if you want me to do that just PM me and I can do it today. Cheers Simeon Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Would anyone on this forum know of a builder/company in Brisbane with house designs for a shallow block. I have a block 20 x 20 so with front and rear set backs I need a… 0 4825 Yes, Im following your Lindfield build, looks amazing. 4 1749 Hi, Seeking volume or semi-custom builder in victoria(east), which have existing double story wide floor plans. Seeking 18-20m wide homes with depth of 12-15m long. Or… 0 25413 |
