Browse Forums Building A New House Re: Kitchen island 2Sep 19, 2021 11:53 pm MegKo Can I install kitchen island post tiling or laminate? Anything in specific that I need to take care of? Note - it will be just a square island with no sink. Yes you can. The cabinetry has to sit on a solid surface so tiles would be ok to sit directly on top of. If it's on laminate you will have to cut the flooring so you sit back on the concrete slab. That would obviously have to be done carefully so you can cover the cuts with the panels or beading. Realistically, you will probably be able to tell that it's a slightly different installation to the existing cabinets particularly if you sit on tiles, but if done well by someone who knows what they are doing you would be fine. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6573 The gap can be adjusted so it's tighter. You can definitely set up corner cabinets to have the same gap as standard doors. 2 13456 No. It's not original. Circa early to mid 90s would be my guess and maybe even as late as early 2000s 1 6586 |
