Block orientation and plan suggestions
Attaching the home plan as well, I'm bit concerned if I would have enough light in the entrance foyer. The entrance door will be 1200 mm should I be upgrading to double door?
The orange boundary on the plan is where brick pier colorbond fence will be put, Green boundary will be hedging and pink boundary is colorbond fence.
Unless you want to re-design your whole house. You can make your frontage/main entrance on the other street if possible. That way it's facing east and you can have slightly more light in the morning.
For your south facing block, your entrance will be darker than rest of the house especially you have a good sized porch. But why is it a concern for you? It's a hallway anyway. It's not a living space. Your main living space is at back of the house which is facing north. That will be very nice already.
Thanks Jason... maybe I'm just overthinking for the hallway. I just felt this because the hallway is around 9 to 11 m long. But I should get some light if I leave couple of room doors open.
We find that the awning windows don't let much breeze in, I would consider swapping the front for sliding.
Our house faces south-east and has a very similar facade. We have a 1.2m wide door with 6 frosted glass panels. I have never found the hallway dark at all. Our hallway is around 8m long.
Ah nice! That's assuring... thank u!
Hello... I'm looking for advice on the south facing corner block. To right of the block you have a small park.
for any internal rooms including downstairs halls, under stairs and and windowless rooms consider Solar Skylights that add daylight without needing direct access to outside..very happy with ours
3
ideal house depends on the site and location as much as internal floor plan....what is the distance from the house to all four boundaries, where is north, describe your…
1/04/2024
9
Hi Mofflepop, I would recommend finding a building designer to prepare plans, they should design to your specified budget. The benefit is you can tender the project out…
