Browse Forums Building A New House 1 Aug 28, 2021 6:15 pm I'm building 2 townhouses side by side and going to subdivide. I need to install an underground pit for the electricity and filling out the application form for Jemena and have some questions 1. Do I need just 1 pit or do I need 2 pits (1 for each property) 2. What is the rate of supply (Amps and kW) that I should put on the application (already just my air conditioning for each unit is 23kW) 3. If I get a 3 phase pit installed by the Electricity company, is there anything on the builder side (electrician) that is needed extra. (ie, if the builder is assuming single phase in their quotation, if the supply is 3 phase is there anything that will be needed that would make the cost go up on the builder side) Re: Connection Application for Underground Electricity Suppl 2Aug 30, 2021 11:31 am I think you only need 1 pit regardless of how many units you are building. My application form seemed to have 100amps as a limited. Application with more than 100amps needs special assessment. I got 40amps. Probably best to ask your electrician. My builder requested what they'd want, and I put in the application. Re: Connection Application for Underground Electricity Suppl 3Aug 31, 2021 10:26 pm As a follow up, can I ask people what were there costs quoted by the Electricity company to install the underground pit (I've been quoted $6403 + GST, for a grand total of $7044) Re: Connection Application for Underground Electricity Suppl 4Sep 01, 2021 11:22 am donaldlj As a follow up, can I ask people what were there costs quoted by the Electricity company to install the underground pit (I've been quoted $6403 + GST, for a grand total of $7044) Mine was $4.5k including gst from United Energy in Melb. Cost can be associated with the length of cable needed from pole position to your property. Thanks for the response! However, it's have been sorted. But for others benefit here is what we had to do. Unfortunately, it's not straightforward. BCC washed their hands… 3 7205 Hi JW I just read your post and I find this situation quite strange. When we build, we get a temp pole for construction which becomes the permanent pole for one of the… 1 3944 1 4087 |
