Browse Forums Building A New House 1 Aug 12, 2021 2:25 pm Hello Everyone, For the colorbond roofing blanket what choices are available in the market and what is majorly preferred. I have come across Anticon 60 but there are few more like - Knauf - https://www.nogapinsulation.com.au/prod ... r1-3-55mm/ RM industries - https://rmindustries.com.au/roofing-blanket/ I have seen Anticon 60 used across various build but just wanted to understand the differences and if something needs to be take care of while selection. Thanks ! Re: Colorbond Roofing Insulation 2Oct 10, 2021 5:07 am Ozshaz Hello Everyone, For the colorbond roofing blanket what choices are available in the market and what is majorly preferred. I have come across Anticon 60 but there are few more like - Knauf - https://www.nogapinsulation.com.au/prod ... r1-3-55mm/ RM industries - https://rmindustries.com.au/roofing-blanket/ I have seen Anticon 60 used across various build but just wanted to understand the differences and if something needs to be take care of while selection. Thanks ! I'm interested to know too as on Sunshine Coast and I have raked ceiling with exposed beams so this will be the only insulation method I can have so want the best to keep the heat out. I plan on installing an undercover walkway (awning ??) from my carport to the back door as shown in sketch. I will be using Boxspan Beams and have no concerns regarding… 0 784 Your house roof does not show rusting other than some surface rust on the flashings. In my opinion you dont need to replace or paint the roof other than treat surface rust… 1 10232 Hi all, Our boundary perimeter fences need replacing (3 sides). From everyone's experience, what would you install? Timber lapped and capped OR colorbond? Thank you. 0 2893 |
