Browse Forums Building A New House 1 Aug 12, 2021 1:35 am Hi guys.. looking at the lot picture and the house plan I have currently is the garage possible in the front which will be my primary frontage or rear garage is the only option? Would like to know pros and cons of both. It's a corner lot - size is 397 sqm and we are thinking to build 34 squares home (ground plan is 133 sqm) with a small pool at the sideyard. Currently I have rear design option in hand but fitting the pool seems to be tight hence looking for some suggestions. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Garage in corner lot 2Aug 13, 2021 6:24 pm MegKo Hi guys.. looking at the lot picture and the house plan I have currently is the garage possible in the front which will be my primary frontage or rear garage is the only option? Would like to know pros and cons of both. It's a corner lot - size is 397 sqm and we are thinking to build 34 squares home (ground plan is 133 sqm) with a small pool at the sideyard. Currently I have rear design option in hand but fitting the pool seems to be tight hence looking for some suggestions. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ do you have the plans showing the front garage on this block of land and showing the distance from the house to the rear fence, length and width of the block, upstairs floor plan and direction of north Thanks again for this information. If you do hear anything different, would be great to know 4 8421 4 14713 Dear all, Requesting your help in relation to a CDC code. We are building a new home in NSW on a corner lot (500m2, 15m wide) following Greenfield CDC code. Our design… 0 6310 |
