Browse Forums Building A New House 1 Aug 11, 2021 11:30 am Hi: We are in the process of a knock-down and rebuild in the eastern suburbs. As part of the new build, we require a stormwater outfall drain to be constructed that connects from our stormwater pit to an easement/pit located on the neighbouring property. We've already had a design drawn up by a civil engineer and this has been approved by Council. We're now looking for a drainage plumber to construct per the design. Wondering if anyone else has gone through the same process and if they have any plumbers specialising in this area they would recommend? Thank you. Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for… 4 4554 Agreed. I just found out today the certifier has not given the final sign off. 2 4108 Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 8507 |
