Browse Forums Building A New House 1 Aug 06, 2021 2:12 pm Hi All, I have no idea about doors and was hoping someone could help me! I have chosen a front entrance door: Urban PURB 101 (corinthian.com.au) and would prefer something secure and solid. So I can get this door and then pay a little bit extra and get a solid MDF door. Is it worth the $$ to get MDF? Or is Coritech solid enough? thank you! Re: Front Entrance Door - Solid MDF or Coritech 2Aug 06, 2021 5:54 pm If you upgrade to a BAL12.5 door (see bottom of that link) that will give you a solid MDF core, so yes you can and I believe it's worth it Probably a not bad thing to mention particle board should in case anyone else reading this got the two confused. 6 4906 The warning is on the sticker on the door too. Second the aluminium powdercoat 6 18204 If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8324 |
