Browse Forums Building A New House 1 Aug 03, 2021 1:28 pm Building in Perth. Where do I locate the alfresco to maximise winter sun but minimise summer sun? Leave it where it is? Or move to master side? If moved to master, do I put a highlight window on the northern wall? What role can a deciduous planted pergola play? I need advice from someone experienced ππ»π€πΌπ€πΌ Please note that some changes have been made to this plan including moving bed 2 highlight window to southern wall. I plan to increase eaves on the south western side of the house and use planting along all sides too. The rear of my block runs along an easement with retained bush land and trees. Advice graciously accepted. Iβve posted this elsewhere too. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Help with orientation please 2Aug 03, 2021 3:58 pm I think the orientation is already fairly ideal. Northern eastern is good. Plenty of sunlight into your kitchen and living. Harsh summer sunlight will be behind the house in the afternoon. If you are concerned about your alfresco, I don't know if there is much else you could do. If you locate it next to master bed, you will need to change the masterbed window which will be looking at a fence. One thing you could do is to have no roof over that alfresco area. It will be more like a courtyard outside your kitchen/living. For entertaining, you could install that open/shut pergola thing later. A permanent roof will definitely block some light into the kitchen. Re: Help with orientation please 3Aug 03, 2021 9:29 pm Thanks so much responding, I really appreciate the feedback Jason526 I think the orientation is already fairly ideal. Northern eastern is good. Plenty of sunlight into your kitchen and living. Harsh summer sunlight will be behind the house in the afternoon. If you are concerned about your alfresco, I don't know if there is much else you could do. If you locate it next to master bed, you will need to change the masterbed window which will be looking at a fence. One thing you could do is to have no roof over that alfresco area. It will be more like a courtyard outside your kitchen/living. For entertaining, you could install that open/shut pergola thing later. A permanent roof will definitely block some light into the kitchen. Re: Help with orientation please 4Aug 04, 2021 5:49 pm Yaznco Building in Perth. Where do I locate the alfresco to maximise winter sun but minimise summer sun? Leave it where it is? Or move to master side? If moved to master, do I put a highlight window on the northern wall? What role can a deciduous planted pergola play? I need advice from someone experienced ππ»π€πΌπ€πΌ Please note that some changes have been made to this plan including moving bed 2 highlight window to southern wall. I plan to increase eaves on the south western side of the house and use planting along all sides too. The rear of my block runs along an easement with retained bush land and trees. Advice graciously accepted. Iβve posted this elsewhere too. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ check YourHome.gov for specific advice about Solar orientation for your area but the existing alfresco location is ideal for evening meals and an open pergola over the other end of the outdoor area with either a deciduous vine or removable shade would be more flexible and can be added or removed as you decide how the space will be used (eg late late afternoon winter: still sunny late afternoon summer needs to be fully shaded and, unless you expect to spend long daylight hours in the master bedroom i would move bedroom window and omit the extra sliding doors in master and media that restrict furniture placement, prevent full use of the outdoor area and offer a direct view of your bedroom form the kitchen dining area .... i've included a few ideas for a more comfortable entry, ens, bathroom and laundry and a full vanity in the powder room adds convenient handwashing and extra storage and dual access to the line storage could be useful but i was not able to recreate the original room sizes shown in your plans for this size block of land and substituted room sizes that i think will fit the space so double check with your designer to make sure the final plans have correct dimensions for every room Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Help with orientation please 5Aug 04, 2021 6:57 pm Wow! I absolutely love your ideas! In an ideal world, I would absolutely love this layout. Unfortunately, I have very specific needs which are the primary driver of my current plan. Iβm an electric wheelchair user and for the most part, almost entirely bedbound. This layout lets me be connected to my kids and visitors whilst being stuck in my bed. I know itβs unusual lol. Iβm also highly dependent on care so that factors in too. Iβm really happy with your feedback regarding position of the alfresco and I think the pergola is the way to go. I feel much better about it now. Thanks so much gor taking the time, you have some fabulous skills! oklouise Yaznco Building in Perth. Where do I locate the alfresco to maximise winter sun but minimise summer sun? Leave it where it is? Or move to master side? If moved to master, do I put a highlight window on the northern wall? What role can a deciduous planted pergola play? I need advice from someone experienced ππ»π€πΌπ€πΌ Please note that some changes have been made to this plan including moving bed 2 highlight window to southern wall. I plan to increase eaves on the south western side of the house and use planting along all sides too. The rear of my block runs along an easement with retained bush land and trees. Advice graciously accepted. Iβve posted this elsewhere too. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ check YourHome.gov for specific advice about Solar orientation for your area but the existing alfresco location is ideal for evening meals and an open pergola over the other end of the outdoor area with either a deciduous vine or removable shade would be more flexible and can be added or removed as you decide how the space will be used (eg late late afternoon winter: still sunny late afternoon summer needs to be fully shaded and, unless you expect to spend long daylight hours in the master bedroom i would move bedroom window and omit the extra sliding doors in master and media that restrict furniture placement, prevent full use of the outdoor area and offer a direct view of your bedroom form the kitchen dining area .... i've included a few ideas for a more comfortable entry, ens, bathroom and laundry and a full vanity in the powder room adds convenient handwashing and extra storage and dual access to the line storage could be useful but i was not able to recreate the original room sizes shown in your plans for this size block of land and substituted room sizes that i think will fit the space so double check with your designer to make sure the final plans have correct dimensions for every room Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Help with orientation please 6Aug 04, 2021 7:11 pm Yaznco Wow! I absolutely love your ideas! In an ideal world, I would absolutely love this layout. Unfortunately, I have very specific needs which are the primary driver of my current plan. Iβm an electric wheelchair user and for the most part, almost entirely bedbound. This layout lets me be connected to my kids and visitors whilst being stuck in my bed. I know itβs unusual lol. Iβm also highly dependent on care so that factors in too. Iβm really happy with your feedback regarding position of the alfresco and I think the pergola is the way to go. I feel much better about it now. Thanks so much gor taking the time, you have some fabulous skills! oklouise Yaznco Building in Perth. Where do I locate the alfresco to maximise winter sun but minimise summer sun? Leave it where it is? Or move to master side? If moved to master, do I put a highlight window on the northern wall? What role can a deciduous planted pergola play? I need advice from someone experienced ππ»π€πΌπ€πΌ Please note that some changes have been made to this plan including moving bed 2 highlight window to southern wall. I plan to increase eaves on the south western side of the house and use planting along all sides too. The rear of my block runs along an easement with retained bush land and trees. Advice graciously accepted. Iβve posted this elsewhere too. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ check YourHome.gov for specific advice about Solar orientation for your area but the existing alfresco location is ideal for evening meals and an open pergola over the other end of the outdoor area with either a deciduous vine or removable shade would be more flexible and can be added or removed as you decide how the space will be used (eg late late afternoon winter: still sunny late afternoon summer needs to be fully shaded and, unless you expect to spend long daylight hours in the master bedroom i would move bedroom window and omit the extra sliding doors in master and media that restrict furniture placement, prevent full use of the outdoor area and offer a direct view of your bedroom form the kitchen dining area .... i've included a few ideas for a more comfortable entry, ens, bathroom and laundry and a full vanity in the powder room adds convenient handwashing and extra storage and dual access to the line storage could be useful but i was not able to recreate the original room sizes shown in your plans for this size block of land and substituted room sizes that i think will fit the space so double check with your designer to make sure the final plans have correct dimensions for every room Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ i'm sorry to learn about your disability but pleased that you have good support and plan a new home to make life more comfortable for yourself and your carers, best wishes for a happy new home 0 609 Thankyou so much π I've decided on White on white for doors and trims, White on white 50% on ceiling and Mt buller for walls. Fingers crossed it will look OK π 2 7158 i had the my concreters concrete right up to the fence. I have pits all along my path, so the water tends to drain away from the house and into the pits. There's only one… 7 12774 |
