Browse Forums Building A New House 1 Jul 25, 2021 4:26 pm hi hoping to be able to buy a cheap block in 5-10 years time in kadina or wallaroo probably just out town a little and copper coast council wont allow a shed on a vacant block before house is put on or approval for house is done and you start building and finishing in certain time. what do lot think will make most sense out following financially 1. buy vacant block and put transportable on built to lockup stage and you finish off and do as much as you can yourself and get tradies in for those few things and build one shed to start with. 2. try find a block with shed and later put house on it, not sure what limitations are for work on block or storage without council approval, storage surely shouldnt be a problem if its out town a little. 3. buy cheapest house you can just for the sheds and have a think of wether you want to do up the house or pull it down and rebuild. with transportables what is the least council will approve as have 1st choice, 2nd choice and 3rd choice in mind incase am not able to afford 1st choice. if it comes to having to have the smallest council will approve then may have to do what parents did years back in wallaroo and buy cheapest transportable and extend a few years after. one example is they bought block in wallaroo and put the smallest on it they could get away with for circumstances at time then worked towards extending a few years after, that was back in 91 and in about 95 they built back room. have a few plans from selecta in mind. 1st choice 1. the grand 4 bed/wir/ensuite 2. morialta 3 bed/wir/ensuite 3. willunga 3 bed/ensuite 2nd choice 1. virginia, eventually would build big area and another bedroom with ensuite 2. encounter 3 bed (convert bed 3 into walk in robe and ensuite for main bedroom and double insulate wall between bedroom 1 and bedroom 2) 3. flinders seperate laundry/bathroom whatever plan that end up going with will eventually extend and have a area for the home theatre and when veranda goes up at back then would enclose part of that and turn it into office. would it be cheaper to go with one of the second choices with the eventual changes for the plan and then extend a few years after and put back veranda there or would it be cheaper and easier to just go with a first choice from the start with the extension for home theatre a few years after and part of veranda being turned into office and rest for entertain once that goes up. not in any hurry to shift out the current home and live there permanently just need to put something there or have something there so council will allow you to build sheds then slowly work up with the said plans if anyone is able to help thatd be great thanks Re: buying block and putting shed on it and house 2Jul 25, 2021 4:28 pm daisy20202-7 hi hoping to be able to buy a cheap block in 5-10 years time in kadina or wallaroo probably just out town a little and copper coast council wont allow a shed on a vacant block before house is put on or approval for house is done and you start building and finishing in certain time. what do lot think will make most sense out following financially 1. buy vacant block and put transportable on built to lockup stage and you finish off and do as much as you can yourself and get tradies in for those few things and build one shed to start with. 2. try find a block with shed and later put house on it, not sure what limitations are for work on block or storage without council approval, storage surely shouldnt be a problem if its out town a little. 3. buy cheapest house you can just for the sheds and have a think of wether you want to do up the house or pull it down and rebuild. with transportables what is the least council will approve as have 1st choice, 2nd choice and 3rd choice in mind incase am not able to afford 1st choice. if it comes to having to have the smallest council will approve then may have to do what parents did years back in wallaroo and buy cheapest transportable and extend a few years after. one example is they bought block in wallaroo and put the smallest on it they could get away with for circumstances at time then worked towards extending a few years after, that was back in 91 and in about 95 they built back room. have a few plans from selecta in mind. 1st choice 1. the grand 4 bed/wir/ensuite 2. morialta 3 bed/wir/ensuite 3. willunga 3 bed/ensuite 2nd choice 1. virginia, eventually would build big area and another bedroom with ensuite 2. encounter 3 bed (convert bed 3 into walk in robe and ensuite for main bedroom and double insulate wall between bedroom 1 and bedroom 2) 3. flinders seperate laundry/bathroom whatever plan that end up going with will eventually extend and have a area for the home theatre and when veranda goes up at back then would enclose part of that and turn it into office. would it be cheaper to go with one of the second choices with the eventual changes for the plan and then extend a few years after and put back veranda there or would it be cheaper and easier to just go with a first choice from the start with the extension for home theatre a few years after and part of veranda being turned into office and rest for entertain once that goes up. not in any hurry to shift out the current home and live there permanently just need to put something there or have something there so council will allow you to build sheds then slowly work up with the said plans if anyone is able to help thatd be great thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: buying block and putting shed on it and house 3Jul 25, 2021 4:28 pm daisy20202-7 daisy20202-7 hi hoping to be able to buy a cheap block in 5-10 years time in kadina or wallaroo probably just out town a little and copper coast council wont allow a shed on a vacant block before house is put on or approval for house is done and you start building and finishing in certain time. what do lot think will make most sense out following financially 1. buy vacant block and put transportable on built to lockup stage and you finish off and do as much as you can yourself and get tradies in for those few things and build one shed to start with. 2. try find a block with shed and later put house on it, not sure what limitations are for work on block or storage without council approval, storage surely shouldnt be a problem if its out town a little. 3. buy cheapest house you can just for the sheds and have a think of wether you want to do up the house or pull it down and rebuild. with transportables what is the least council will approve as have 1st choice, 2nd choice and 3rd choice in mind incase am not able to afford 1st choice. if it comes to having to have the smallest council will approve then may have to do what parents did years back in wallaroo and buy cheapest transportable and extend a few years after. one example is they bought block in wallaroo and put the smallest on it they could get away with for circumstances at time then worked towards extending a few years after, that was back in 91 and in about 95 they built back room. have a few plans from selecta in mind. 1st choice 1. the grand 4 bed/wir/ensuite 2. morialta 3 bed/wir/ensuite 3. willunga 3 bed/ensuite 2nd choice 1. virginia, eventually would build big area and another bedroom with ensuite 2. encounter 3 bed (convert bed 3 into walk in robe and ensuite for main bedroom and double insulate wall between bedroom 1 and bedroom 2) 3. flinders seperate laundry/bathroom whatever plan that end up going with will eventually extend and have a area for the home theatre and when veranda goes up at back then would enclose part of that and turn it into office. would it be cheaper to go with one of the second choices with the eventual changes for the plan and then extend a few years after and put back veranda there or would it be cheaper and easier to just go with a first choice from the start with the extension for home theatre a few years after and part of veranda being turned into office and rest for entertain once that goes up. not in any hurry to shift out the current home and live there permanently just need to put something there or have something there so council will allow you to build sheds then slowly work up with the said plans if anyone is able to help thatd be great thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: buying block and putting shed on it and house 4Jul 25, 2021 4:30 pm each plan option for the house itself would be built to lockup stage and you finish as much as you can yourself and get the tradies in for those few things Re: buying block and putting shed on it and house 5Jul 25, 2021 4:53 pm also where it says aged or disabled pension is accepted on list of centrelink incomes that are accepted for small loan if you work part time or guessing have a letter to say you can not work at all do you have to work for someone else or can you run your own business for it to count Re: buying block and putting shed on it and house 6Aug 09, 2021 1:39 am All plans are fine, as long as you feel ok with any of it, in your own home. Two years ago, I made the decision that I want to live a minimalist life. I don't wanna save money for a big house, because I don't need so much for a nice living. Just a place to sleep, a place to eat and take a shower. So, researching what I had to do next, I found out about tiny houses. Guess what? I built a mobile tuff shed on my own. I paid around 2000 $ for everything. I'm happy with my life and what I have. If someone is interested, you can read more information about it here https://shedstuff.org/motorcycle-storage-sheds DIY, Home Maintenance & Repair Are you doing this with a building permit? Conversion of a non habitable room into a habitable room requires building permit. 3 17318 Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4896 Thanks. Yeh ideally that would have been good, but have progressed too far now. Hoping some well placed internal walls fixed up into the battens will provide some… 2 5403 |
