Browse Forums Building A New House 1 Jul 11, 2021 2:08 pm M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Getting TV cables behind the wall through bullnose 2Jul 11, 2021 10:17 pm Follow my build here: https://www.instagram.com/ivy5custom Re: Getting TV cables behind the wall through bullnose 4Jul 12, 2021 9:03 am Follow my build here: https://www.instagram.com/ivy5custom Re: Getting TV cables behind the wall through bullnose 5Jul 12, 2021 10:07 am M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Getting TV cables behind the wall through bullnose 6Jul 12, 2021 12:03 pm Follow my build here: https://www.instagram.com/ivy5custom Re: Getting TV cables behind the wall through bullnose 8Jul 12, 2021 8:08 pm MrsJM Hoping someone can point me in the direction of a website or YouTube video please! We moved in to our new build a few years back and I remember the sparkie left some string behind the wall which we used (can’t recall how!) to get the tv cables behind the wall and out the bottom bullnose plate. There’s one tv we didn’t do and I can’t for the life of me remember how to do it. Appreciate any help. The husband is happy to live with dangling cables so I’m going it alone (not that he was any good with the last lot!) MrsJM I have proudly given myself the title of professional TV installer in my family, as I had to do 4 last year . But I am with the others in that I am not sure what you mean especially by bullnose? Any chance of photos? If you are simply trying to run your HDMI & power cable from the TV through a hole and down to a lower hole, you will need some hard thin long plastic, like the yellow stuff on yellow tongue and then you tape your HDMI cable to it and feed it down the wall cavity. The issue will be if there is a noggin in the way, so if you hit one, you are kind of stuck, you may be able to do some exploring one stud over and hope there isn't one there. If that doesn't work, and you really want to hide the cables you need to drill a hole or cut a rebate through the noggin, which would mean cutting a hole in the plasterboard first and then we are getting into a big job. fingers crossed that the carpenters installed the noggins above the TV Cheers Simeon Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Old Home Restoration / Renovation Hi, just discovered all these junks left behind under the floor. Could any of these be asbestos? Best to leave as it is or clean up? Thank you for your thoughts 0 8070 yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7320 Hi When it rains in a particular direction water comes through the security door. It hits the main door and the bottom swells and jams. There is already a cover over the… 0 38444 |
