Browse Forums Building A New House 1 Jul 11, 2021 2:08 pm M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Getting TV cables behind the wall through bullnose 2Jul 11, 2021 10:17 pm Not really sure what you're question is but it sounds like you need an electrician. While i'm certainly not one to shy away from running cables yourself though the walls, just remember that technically it is illegal to do so. Follow my build here: https://www.instagram.com/ivy5custom Re: Getting TV cables behind the wall through bullnose 3Jul 11, 2021 11:09 pm Monty85 Not really sure what you're question is but it sounds like you need an electrician. While i'm certainly not one to shy away from running cables yourself though the walls, just remember that technically it is illegal to do so. you can use a stiff piece of plastic, often the yellow tongue of chipboard flooring, only problems are insulation and noggings. Re: Getting TV cables behind the wall through bullnose 4Jul 12, 2021 9:03 am Pulse Monty85 Not really sure what you're question is but it sounds like you need an electrician. While i'm certainly not one to shy away from running cables yourself though the walls, just remember that technically it is illegal to do so. I think they mean HDMI, Aerial and the power cord which is legal. you can use a stiff piece of plastic, often the yellow tongue of chipboard flooring, only problems are insulation and noggings. I'm almost certain you're not supposed to run a power cord through a wall (through conduit) but happy to be proven wrong. Follow my build here: https://www.instagram.com/ivy5custom Re: Getting TV cables behind the wall through bullnose 5Jul 12, 2021 10:07 am Monty85 Pulse Monty85 Not really sure what you're question is but it sounds like you need an electrician. While i'm certainly not one to shy away from running cables yourself though the walls, just remember that technically it is illegal to do so. I think they mean HDMI, Aerial and the power cord which is legal. you can use a stiff piece of plastic, often the yellow tongue of chipboard flooring, only problems are insulation and noggings. I'm almost certain you're not supposed to run a power cord through a wall (through conduit) but happy to be proven wrong. M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Getting TV cables behind the wall through bullnose 6Jul 12, 2021 12:03 pm MrsJM Yep what Pulse explained is what we are trying to do. We had the bullnose installed for our wall mounted tv and we connected a soundbar which sits on the unit and I want to feed the power cord through the bullnose to the tv to connect it rather than leave it dangling Is there conduit from the top bullnose plate to the bottom one? As in, is there a pipe that goes from one to other? Still not 100% sure on what you trying to do - maybe take some pictures. Again though, feeding a power cord through the wall is not advised. Follow my build here: https://www.instagram.com/ivy5custom Re: Getting TV cables behind the wall through bullnose 7Jul 12, 2021 7:57 pm I’m 100% certain it’s OK, it is plugged into a GPO and not part of fixed wiring. Pretty standard way to do it, alternatively you need a GPO behind the TV. You just need some yellow tongue and electrical tape to tape the IEC end of the cable to the yellow tongue Re: Getting TV cables behind the wall through bullnose 8Jul 12, 2021 8:08 pm MrsJM Hoping someone can point me in the direction of a website or YouTube video please! We moved in to our new build a few years back and I remember the sparkie left some string behind the wall which we used (can’t recall how!) to get the tv cables behind the wall and out the bottom bullnose plate. There’s one tv we didn’t do and I can’t for the life of me remember how to do it. Appreciate any help. The husband is happy to live with dangling cables so I’m going it alone (not that he was any good with the last lot!) MrsJM I have proudly given myself the title of professional TV installer in my family, as I had to do 4 last year . But I am with the others in that I am not sure what you mean especially by bullnose? Any chance of photos? If you are simply trying to run your HDMI & power cable from the TV through a hole and down to a lower hole, you will need some hard thin long plastic, like the yellow stuff on yellow tongue and then you tape your HDMI cable to it and feed it down the wall cavity. The issue will be if there is a noggin in the way, so if you hit one, you are kind of stuck, you may be able to do some exploring one stud over and hope there isn't one there. If that doesn't work, and you really want to hide the cables you need to drill a hole or cut a rebate through the noggin, which would mean cutting a hole in the plasterboard first and then we are getting into a big job. fingers crossed that the carpenters installed the noggins above the TV Cheers Simeon Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Old Home Restoration / Renovation Hi, just discovered all these junks left behind under the floor. Could any of these be asbestos? Best to leave as it is or clean up? Thank you for your thoughts 0 8059 yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7298 Hi When it rains in a particular direction water comes through the security door. It hits the main door and the bottom swells and jams. There is already a cover over the… 0 38443 |
