Browse Forums Building A New House Re: Island bench Waterfall edges - Perth 2Jul 11, 2021 12:06 am I was quoted roughly $2k for one side only! So looking at $4k if want the waterfall edge on both sides. Building with a volume builder so not much room for any negotiation. I'm sure you can get it done for cheaper through a custom builder. Re: Island bench Waterfall edges - Perth 3Jul 11, 2021 4:14 pm smsaaos I was quoted roughly $2k for one side only! So looking at $4k if want the waterfall edge on both sides. Building with a volume builder so not much room for any negotiation. I'm sure you can get it done for cheaper through a custom builder. ....4k whateven man... DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6591 Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11709 Building Standards; Getting It Right! These can be easily filled and repaired and it doesn't cost them much to do. Id get the builder to do this first and if the repair is not suitable then a replacement is… 12 31280 |
