Browse Forums Building A New House 1 Jul 01, 2021 12:46 am Hi all, I am in the processing of building a house in the fairfield council area (nsw 2166). I have decided on a home builder and they initially said I could go thru CDC based on my lot and my 10.7 certificate. After I paid for my contour survey, it was then determined that I could not go thru CDC They said it was because my contour survey came back and my AHD level was 13.1. My lot is partly medium and partly low as a result of overland flooding and my 10.7 certificate showed some flood levels, the 1 to 100 year flood max was 13.5 ahd So i was told that because contour AHD showed (13.1) which was below the 13.5, they said I can't go thru CDC and I must go through DA. Does anyone know if this is true? I did contact a random Architect to query this and provided the same info above and they think I can go through CDC even though my contour adh level was below the maximum flood level on my 10.7 certificate. So I am abit lost. Do you know if my situation above would allow me to go thru CDC? Is it worth going to another builder? The issue is that I have already spent so much time with this particular builder, I don't know if I went elsewhere if the result would be any different? I don't have time to do owner builder, so I can't go down the route of architect and building myself etc Any help is appreciated, reason I prefer CDC is because it's alot quicker, but mainly because it offers a better floor space ratio than DA Thanks Re: CDC query - AHD & Flood Levels 2Jul 02, 2021 5:11 pm rookie1 Hi all, I am in the processing of building a house in the fairfield council area (nsw 2166). I have decided on a home builder and they initially said I could go thru CDC based on my lot and my 10.7 certificate. After I paid for my contour survey, it was then determined that I could not go thru CDC They said it was because my contour survey came back and my AHD level was 13.1. My lot is partly medium and partly low as a result of overland flooding and my 10.7 certificate showed some flood levels, the 1 to 100 year flood max was 13.5 ahd So i was told that because contour AHD showed (13.1) which was below the 13.5, they said I can't go thru CDC and I must go through DA. Does anyone know if this is true? I did contact a random Architect to query this and provided the same info above and they think I can go through CDC even though my contour adh level was below the maximum flood level on my 10.7 certificate. So I am abit lost. Do you know if my situation above would allow me to go thru CDC? Is it worth going to another builder? The issue is that I have already spent so much time with this particular builder, I don't know if I went elsewhere if the result would be any different? I don't have time to do owner builder, so I can't go down the route of architect and building myself etc Any help is appreciated, reason I prefer CDC is because it's alot quicker, but mainly because it offers a better floor space ratio than DA Thanks Rookie1 I am going to PM you my number as I want to put you in touch with the guy that we use who is literally the GURU of CDC. He designs and approves around 700 homes a year and there isnt a loophole he doesnt know. If you cant do it he will also tell you. Anyway give me a call and I will fill you in Cheers Simeon Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: CDC query - AHD & Flood Levels 4Aug 01, 2021 7:48 am Hi Simeon, Could I get your cdc guru’s number as well? Many thanks Judy Ashington Homes rookie1 Hi all, I am in the processing of building a house in the fairfield council area (nsw 2166). I have decided on a home builder and they initially said I could go thru CDC based on my lot and my 10.7 certificate. After I paid for my contour survey, it was then determined that I could not go thru CDC They said it was because my contour survey came back and my AHD level was 13.1. My lot is partly medium and partly low as a result of overland flooding and my 10.7 certificate showed some flood levels, the 1 to 100 year flood max was 13.5 ahd So i was told that because contour AHD showed (13.1) which was below the 13.5, they said I can't go thru CDC and I must go through DA. Does anyone know if this is true? I did contact a random Architect to query this and provided the same info above and they think I can go through CDC even though my contour adh level was below the maximum flood level on my 10.7 certificate. So I am abit lost. Do you know if my situation above would allow me to go thru CDC? Is it worth going to another builder? The issue is that I have already spent so much time with this particular builder, I don't know if I went elsewhere if the result would be any different? I don't have time to do owner builder, so I can't go down the route of architect and building myself etc Any help is appreciated, reason I prefer CDC is because it's alot quicker, but mainly because it offers a better floor space ratio than DA Thanks Rookie1 I am going to PM you my number as I want to put you in touch with the guy that we use who is literally the GURU of CDC. He designs and approves around 700 homes a year and there isnt a loophole he doesnt know. If you cant do it he will also tell you. Anyway give me a call and I will fill you in Cheers Simeon Re: CDC query - AHD & Flood Levels 5Aug 06, 2021 1:48 pm rookie1 Hi all, I am in the processing of building a house in the fairfield council area (nsw 2166). I have decided on a home builder and they initially said I could go thru CDC based on my lot and my 10.7 certificate. After I paid for my contour survey, it was then determined that I could not go thru CDC They said it was because my contour survey came back and my AHD level was 13.1. My lot is partly medium and partly low as a result of overland flooding and my 10.7 certificate showed some flood levels, the 1 to 100 year flood max was 13.5 ahd So i was told that because contour AHD showed (13.1) which was below the 13.5, they said I can't go thru CDC and I must go through DA. Does anyone know if this is true? I did contact a random Architect to query this and provided the same info above and they think I can go through CDC even though my contour adh level was below the maximum flood level on my 10.7 certificate. So I am abit lost. Do you know if my situation above would allow me to go thru CDC? Is it worth going to another builder? The issue is that I have already spent so much time with this particular builder, I don't know if I went elsewhere if the result would be any different? I don't have time to do owner builder, so I can't go down the route of architect and building myself etc Any help is appreciated, reason I prefer CDC is because it's alot quicker, but mainly because it offers a better floor space ratio than DA Thanks On your 10.7 cert, are you in a flood zone? Re: CDC query - AHD & Flood Levels 6Aug 06, 2021 1:54 pm rookie1 Hi all, I am in the processing of building a house in the fairfield council area (nsw 2166). I have decided on a home builder and they initially said I could go thru CDC based on my lot and my 10.7 certificate. After I paid for my contour survey, it was then determined that I could not go thru CDC They said it was because my contour survey came back and my AHD level was 13.1. My lot is partly medium and partly low as a result of overland flooding and my 10.7 certificate showed some flood levels, the 1 to 100 year flood max was 13.5 ahd So i was told that because contour AHD showed (13.1) which was below the 13.5, they said I can't go thru CDC and I must go through DA. Does anyone know if this is true? I did contact a random Architect to query this and provided the same info above and they think I can go through CDC even though my contour adh level was below the maximum flood level on my 10.7 certificate. So I am abit lost. Do you know if my situation above would allow me to go thru CDC? Is it worth going to another builder? The issue is that I have already spent so much time with this particular builder, I don't know if I went elsewhere if the result would be any different? I don't have time to do owner builder, so I can't go down the route of architect and building myself etc Any help is appreciated, reason I prefer CDC is because it's alot quicker, but mainly because it offers a better floor space ratio than DA Thanks On your 10.7 cert, are you in a flood zone? Re: CDC query - AHD & Flood Levels 9Nov 15, 2021 6:48 pm Hi Simeon, can you please PM me the contact details of the guy you talked about? I'm in a similar situation to rookie1 - was ready to proceed with CDC until a land survey was done. The builder is saying we have to go through DA now since our land is in a flood affected zone. Re: CDC query - AHD & Flood Levels 10Nov 15, 2021 7:02 pm EP1 Hi Simeon, can you please PM me the contact details of the guy you talked about? I'm in a similar situation to rookie1 - was ready to proceed with CDC until a land survey was done. The builder is saying we have to go through DA now since our land is in a flood affected zone. Hi EP1 I'll PM you. Not an expert but my duplex build is in a flood zone as well. I am in North Ryde and I applied to Ryde council for their required FFL's and they gave me a report with a RL above the PMF and I am able to use CDC. I know this is not available to everyone in a flood zone. I hope you can get the answer you need Simeon Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Yes it had a house on it. But Melbourne water only wanted something the original size of the existing house. We managed to fit a 45sq house on. 10 33654 Give Jonathan a call. Tell him you know me. He is in my opinion the best surveyor I have ever worked with. His number is 0425 285 622 All the best Simeon 3 12362 5 6802 |
