Browse Forums Building A New House 1 May 21, 2021 6:43 am Hi everyone We have missed the boat on a fireplace. We have signed contracts and apparently it's too late to add a fireplace - not even as a building variation. This is why I am now wondering how difficult it is to install a fireplace after handover? Has anyone had any experience with this? Thanks. Re: Fireplace install after handover 2May 21, 2021 9:24 am Did they allow for the slab thickening in the slab for the point load (Fireboxes loaded with wood are quite heavy). If not then you will be responsible for floor covering cracking ie tiles Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Fireplace install after handover 3May 21, 2021 9:57 am We did a fire box after handover in late 90s,ended up adding blueboard ,then rendering with box being outside of exterior wall. Probably would need maybe 3 different trades depending on what's inside and outside of house. It was well worth it but too long ago to remember costs. Re: Fireplace install after handover 4May 21, 2021 10:51 am Your biggest problem is that you will be the second builder interfering with first builder's work. It may place you in a position of blame if something goes wrong or at least blurring areas of responsibility. If you do it make sure it is properly assessed and properly constructed. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Hi all, My first post, we are building a house and can’t decide the layout of the lounge room. We have a large N/W facing window and are wanting to have a wood slow… 0 13729 No the fireplace doesn’t work. It’s been enclosed. I’m not sure what was removed, as it was done quite some time ago - well before what I can see with photos online… 2 11589 I would probably render it and then paint it as per your other advice, or gyrpock over the top. 1 3344 |
