Browse Forums Building A New House 1 Feb 11, 2022 1:43 pm Has anyone seen something like this dip in their concrete? SS says its for drainage !
Re: Is this drainage in concrete normal? 2Feb 11, 2022 4:07 pm Looks like your slab there is defective - not flat and level. This defect may be repeated elsewhere. Suggest you get a 2 metre straight edge and check the rest of it against the NSWDFT allowable tolerance. Document your findings with suitable photos. Make sure Better Built Homes levels it, and you personally check its done, before floor coverings are installed. What does your private inspector say about this?
Re: Is this drainage in concrete normal? 4Feb 11, 2022 8:52 pm Your super was being a smart as_. Its not ideal, but your cabinetry will cover it. Wait until the cabinets are in and see if the hollow section is noticeable in your walk way, if it is ask them how they intend to fix it. If the hollow under the cupboards its a major concern to you (structural it's not a problem) ask the builder to put some self leveler in the hollow. We are Expert Consultant's, and we are here to help. Re: Is this drainage in concrete normal? 6Feb 12, 2022 2:24 pm Kippers01 What an awesome design idea from BBH. Drainage features built into the slab for when their roof leaks! Aaah! The scepticism of youth. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Do you have solar on the roof, because if its not a laying defect it looks almost like someone has been walking all over the roof in the mid section of the tile (weakest… 2 2116 Yes, get a builder, make sure he is experienced and a registered building practitioner 5 9257 |
