Browse Forums Building A New House 1 May 19, 2021 4:21 pm Hi Everyone We are building a double storey home in Melbourne. The block is width is 9.5m and depth is 47m. North is on the right side of the property (same side as stairs) I have attached the floor plan. We appreciate all comments and critiques. We plan to halve the void to make the rumpus room bigger upstairs. I welcome your thoughts on how this can be improved. Thank you so much for your help. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Thoughts on new house plans 3May 19, 2021 9:33 pm That dining room window will just be a view of a brick wall. I would looking to make the rear window /door wider and delete the dining room window. If you reduce the size of the void your hallway is going to be very gloomy. Bedheads below a window are a recipe for a stiff neck in winter as you will get cold down drafts. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Thoughts on new house plans 4May 20, 2021 11:25 am Now would probably be a good time to assess, engineering, material handling, crane, extra over costs, etc hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Thoughts on new house plans 5Feb 11, 2022 1:09 am Those signs are horrid, I would be embarrassed for the poor owner to display something like those, thankfully your not promoting your business and don't have a conflict! Zipzap, the glass windows to the front elevation will work, they will soften the bulkiness of the façade which can always be a challenge on <10m wide with a double storey. Especially as the left has a high brick fence that that will wrap around and act as an extension to your solid walls, without the glass to draw your eye in it would appear quite tall, hard and imposing. The layout works well and has a good flow. The NCC-BCA 2022 due Sep 1st, includes requirements for LHA (Livable Housing Australia). The only suggestion is if you applied LHA to the downstairs guest room your home would comply with Adaptable Housing. It would require the bathroom's slab area to be recessed 75mm-85mm as it would become a Future Wet room. You could still have the shower screen door but you have the ability to remove it to comply. The recess is to meet the <5mm height transition at the door. The Fed Gov is not going to keep pouring money into old peoples homes, this LHA inclusion into the codes is to develop housing stock for the future oldies to staying at home or with family. So the Gov can wind back funding +4-5yrs Great Design We are Expert Consultant's, and we are here to help. Re: Thoughts on new house plans 6Feb 12, 2022 7:47 pm overall I think it's a good plan. ground floor - add awnings to dining and living area windows on north side. this will save from sun heat in summer. will move the study door to corner/stairs side to utilise the room more first floor - good to add some windows in the passage way of bed 1 agree with bashworth, removing void can make hallway gloomy and a big pendant lamp there will add a solid feature to your home. but given you have big windows to your stairs and big opening towards powder room, that should provide open feeling so in my opinion, it should still be ok to remove void and add more rumpus room. as bashworth said, I will remove windows above bedheads from bed 4. bed 3 you can move the bed to bathroom wall and have bigger windows on north side. Really tight at the top of the stairs- how to get furniture into those rooms? Study books - does anyone really use them these days? Large storage closet would be more functional. 2 6884 Were struck with: Colorbond Ironstone Grey roof and cream windows. What color should we render and paint the garage door to tone down the cream windows? Farm House, will… 0 26652 Ask the council if there is a chance of getting build over easement exemption. Sometimes easements are unused and 24cm is not all that much. Good luck. And yes any builder… 2 13769 |
