Browse Forums Building A New House Re: Is bricks to paint white is more costly than rendering i 2May 17, 2021 1:07 pm With regards to painting, are you aiming to paint over the whole thing, or paint each brick individually and leave the mortar between them unpainted? I'd imagine painting the whole thing would be cheaper, than rendering the bricks first, and then painting the render in white color. You could also consider just using white bricks with white mortar to achieve slightly different look. I think the burlesque range is essentially painted bricks: https://australbricks.com.au/qld/produc ... atchid=317 Re: Is bricks to paint white is more costly than rendering i 3May 17, 2021 2:49 pm Kate97 Building a new house and in the process of choosing a builder. Would like discuss about many things related to building as they come. Is rendering less costly than painting bricks white in exterior walls? Hi Kate97 No sure where you are from but in Sydney acrylic render costs around $55-65/sqm depending on which contractors are available at the time. Sand and cement is a bit cheaper but does tend to have a reputation for cracking especially in drier periods. On a typical 4-5 bedroom 2 storey home you will end up with wall areas totally circa 400sqm, so acrylic render would be approx $24,000 give or take. If you were to paint, I would use a spray on system, not sure how long that would last as I have never done it but as a guess if someone quoted me $10-12k I would think that was fair. An alternate to painting or render would be the Taubmans Moroka system. I haven't used this since 2005 so have no idea what it currently costs, but its a very fast system to apply, From memory I think we did a 2 story house in 2 days so at a guess maybe $40/sqm so $16,000. I might actually get a quote on that to confirm I hope this helps a little Good luck with your decision Simeon Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Is bricks to paint white is more costly than rendering i 4May 17, 2021 10:17 pm strannik With regards to painting, are you aiming to paint over the whole thing, or paint each brick individually and leave the mortar between them unpainted? I'd imagine painting the whole thing would be cheaper, than rendering the bricks first, and then painting the render in white color. You could also consider just using white bricks with white mortar to achieve slightly different look. I think the burlesque range is essentially painted bricks: https://australbricks.com.au/qld/produc ... atchid=317 Paint the whole thing in a shade of white. Re: Is bricks to paint white is more costly than rendering i 5May 17, 2021 10:20 pm SejaeD Kate97 Building a new house and in the process of choosing a builder. Would like discuss about many things related to building as they come. Is rendering less costly than painting bricks white in exterior walls? Hi Kate97 No sure where you are from but in Sydney acrylic render costs around $55-65/sqm depending on which contractors are available at the time. Sand and cement is a bit cheaper but does tend to have a reputation for cracking especially in drier periods. On a typical 4-5 bedroom 2 storey home you will end up with wall areas totally circa 400sqm, so acrylic render would be approx $24,000 give or take. If you were to paint, I would use a spray on system, not sure how long that would last as I have never done it but as a guess if someone quoted me $10-12k I would think that was fair. An alternate to painting or render would be the Taubmans Moroka system. I haven't used this since 2005 so have no idea what it currently costs, but its a very fast system to apply, From memory I think we did a 2 story house in 2 days so at a guess maybe $40/sqm so $16,000. I might actually get a quote on that to confirm I hope this helps a little Good luck with your decision Simeon Build will be in Ku ring gai council area, Sydney. To paint in a shade of white the whole exterior of the house without rendering. We are talking to the builders who build in the area. Still haven’t chosen one. Re: Is bricks to paint white is more costly than rendering i 6May 18, 2021 8:47 am Kate97 SejaeD Kate97 Building a new house and in the process of choosing a builder. Would like discuss about many things related to building as they come. Is rendering less costly than painting bricks white in exterior walls? Hi Kate97 No sure where you are from but in Sydney acrylic render costs around $55-65/sqm depending on which contractors are available at the time. Sand and cement is a bit cheaper but does tend to have a reputation for cracking especially in drier periods. On a typical 4-5 bedroom 2 storey home you will end up with wall areas totally circa 400sqm, so acrylic render would be approx $24,000 give or take. If you were to paint, I would use a spray on system, not sure how long that would last as I have never done it but as a guess if someone quoted me $10-12k I would think that was fair. An alternate to painting or render would be the Taubmans Moroka system. I haven't used this since 2005 so have no idea what it currently costs, but its a very fast system to apply, From memory I think we did a 2 story house in 2 days so at a guess maybe $40/sqm so $16,000. I might actually get a quote on that to confirm I hope this helps a little Good luck with your decision Simeon Build will be in Ku ring gai council area, Sydney. To paint in a shade of white the whole exterior of the house without rendering. We are talking to the builders who build in the area. Still haven’t chosen one. what advice are your builders giving you? maybe you can get them to all provide quotes on the 3 options so you know exactly Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4889 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7492 yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5228 |
