Browse Forums Building A New House 1 May 12, 2021 11:12 pm Hi All, Firstly, I want to say that I absolutely love this forum and i've learnt a lot reading about all of your experiences and suggestions. We are getting closer to tender stage. I have attached our floor plan. Kindly let me know your suggestions for any updates to the plan. I am looking to see if there are any changes which can improve functionality of the house. Relevant Notes: - Our block is South West facing - Interested in maximising the natural light while taking into account that we want the house to be cool in summer and warm in winter Any help would be greatly appreciated! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: First home build - Floor plan review request 2May 13, 2021 2:02 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Ground Floor - By removing the toilet and changing the doorway to the ensuite, you can create a much larger kitchen. 1st Floor - I would also have only 1 door into the walk in robe (remove the one on the right in the picture). This will allow for space to put bedside tables I would also have only 1 door into the ensuite (remove the one on the right in the picture). This will allow privacy when someone is using the toilet. Alternatively, add a door to the toilet in the ensuite. Re: First home build - Floor plan review request 3May 13, 2021 5:46 pm Its a bit hard to tell from the plans as there arent dimensions but i'd make sure the alfresco is deep enough to be usefull. 3m is probably the minimum, 4m is better. If you've got less than that or the pillars cut in you'll find yourself shuffling between the wall and chairs with a decent table there. Re: First home build - Floor plan review request 4May 13, 2021 8:07 pm My biggest pet hate is sliding external doors in laundries, you have a lot of wasted space in the laundry. Put a normal opening glass door, then you can run cabinetry from wall to wall, you can then narrow the laundry and add that space to the kitchen. I also agree about combining powder and downstairs ensuite (unless someone will live in their permanently, but if its a guest suite combine them), again that will give you more space in your kitchen. Also agree about alfresco being too narrow! Re: First home build - Floor plan review request 5May 13, 2021 9:13 pm Spazzen Its a bit hard to tell from the plans as there arent dimensions but i'd make sure the alfresco is deep enough to be usefull. 3m is probably the minimum, 4m is better. If you've got less than that or the pillars cut in you'll find yourself shuffling between the wall and chairs with a decent table there. Thank you for taking the time to review and your suggestion. I will definitely check on that and ensure that it is at least 3m. We wanted a good amount of backyard space. What is a good dimension for backyard for families with kids? Re: First home build - Floor plan review request 6May 13, 2021 9:41 pm bestspecials Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Ground Floor - By removing the toilet and changing the doorway to the ensuite, you can create a much larger kitchen. 1st Floor - I would also have only 1 door into the walk in robe (remove the one on the right in the picture). This will allow for space to put bedside tables I would also have only 1 door into the ensuite (remove the one on the right in the picture). This will allow privacy when someone is using the toilet. Alternatively, add a door to the toilet in the ensuite. Thank you for taking the time and your suggestion. I am definitely going to think harder about the ground floor suggestion. For the first floor suggestion, while I mentioned functionality of space, I may choose form in the master bedroom. The toilet door suggestion is something I will look into. Re: First home build - Floor plan review request 7May 13, 2021 9:51 pm gogo65 My biggest pet hate is sliding external doors in laundries, you have a lot of wasted space in the laundry. Put a normal opening glass door, then you can run cabinetry from wall to wall, you can then narrow the laundry and add that space to the kitchen. I also agree about combining powder and downstairs ensuite (unless someone will live in their permanently, but if its a guest suite combine them), again that will give you more space in your kitchen. Also agree about alfresco being too narrow! Thank you for taking the time to review and your suggestion. I will get the sliding door changed to a normal one. Would it be one which opens towards the inside of the house? I am definitely thinking about combining the powder and ensuite in the guest room. I will check about the alfresco length. Re: First home build - Floor plan review request 8May 14, 2021 1:37 pm kumaran.pec Spazzen Its a bit hard to tell from the plans as there arent dimensions but i'd make sure the alfresco is deep enough to be usefull. 3m is probably the minimum, 4m is better. If you've got less than that or the pillars cut in you'll find yourself shuffling between the wall and chairs with a decent table there. Thank you for taking the time to review and your suggestion. I will definitely check on that and ensure that it is at least 3m. We wanted a good amount of backyard space. What is a good dimension for backyard for families with kids? How longs a piece of string? Really depends on what you want to do as a family, if you've got little kids and you want a swing, cubby and room for a dog 100-200m2 should be fine. If you're planning to kick the footy or play backyard cricket you'll probably want a bit more, maybe 400m2 don't expect to be booting it though. Anything more than that and odds are you're regional or paying a fortune for the land. And consider the shape, 200m2 in a rectangle off the back of the house is more usable than the same size backyard in a u shape around the house or a courtyard surrounded by house. Re: First home build - Floor plan review request 9May 14, 2021 10:23 pm Spazzen kumaran.pec Spazzen Its a bit hard to tell from the plans as there arent dimensions but i'd make sure the alfresco is deep enough to be usefull. 3m is probably the minimum, 4m is better. If you've got less than that or the pillars cut in you'll find yourself shuffling between the wall and chairs with a decent table there. Thank you for taking the time to review and your suggestion. I will definitely check on that and ensure that it is at least 3m. We wanted a good amount of backyard space. What is a good dimension for backyard for families with kids? How longs a piece of string? Really depends on what you want to do as a family, if you've got little kids and you want a swing, cubby and room for a dog 100-200m2 should be fine. If you're planning to kick the footy or play backyard cricket you'll probably want a bit more, maybe 400m2 don't expect to be booting it though. Anything more than that and odds are you're regional or paying a fortune for the land. And consider the shape, 200m2 in a rectangle off the back of the house is more usable than the same size backyard in a u shape around the house or a courtyard surrounded by house. It was a very open ended question. Thank you for your time and response. There is definitely a pet dog in the future. Other main things are a garden bed and a trampoline. Based on estimation, it will be between 90 - 120m2. It is a rectangular shape. Re: First home build - Floor plan review request 10May 15, 2021 2:29 pm I prefer am l shaped kitchen with and island and no sink in the island. Id move the laundry door to the centre and do storage the whole length, with wm etc on the other side Re: First home build - Floor plan review request 11May 16, 2021 11:50 am alymei I prefer am l shaped kitchen with and island and no sink in the island. Id move the laundry door to the centre and do storage the whole length, with wm etc on the other side Thank you for your time and suggestion. We wanted a long kitchen and do not prefer an L shape for it. Based on an earlier suggestion, We have requested the external laundry door to be converted into a standard one instead of sliding and place opposite to the internal laundry door. This is to keep the appliances and cabinetry on one side with wall to wall setup. Re: First home build - Floor plan review request 12May 16, 2021 3:47 pm kumaran.pec Hi All, Firstly, I want to say that I absolutely love this forum and i've learnt a lot reading about all of your experiences and suggestions. We are getting closer to tender stage. I have attached our floor plan. Kindly let me know your suggestions for any updates to the plan. I am looking to see if there are any changes which can improve functionality of the house. Relevant Notes: - Our block is South West facing - Interested in maximising the natural light while taking into account that we want the house to be cool in summer and warm in winter Any help would be greatly appreciated! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ there seems to be a lot of extra space in the central hallways and gallery that could be better used inside the rooms..based on approximate dimensions my suggestions include bigger guest bedroom, guest bath, pwdr, laundry and pantry ..upstairs rearranging the master suite and moving the WIL allows for better connection between ens and wiw, more storage walls in wiw, bigger twin vanities, north view for the bath, bigger bed 2 and study nook, separate toilet and better bathroom for sharing Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: First home build - Floor plan review request 13May 21, 2021 9:45 pm oklouise kumaran.pec Hi All, Firstly, I want to say that I absolutely love this forum and i've learnt a lot reading about all of your experiences and suggestions. We are getting closer to tender stage. I have attached our floor plan. Kindly let me know your suggestions for any updates to the plan. I am looking to see if there are any changes which can improve functionality of the house. Relevant Notes: - Our block is South West facing - Interested in maximising the natural light while taking into account that we want the house to be cool in summer and warm in winter Any help would be greatly appreciated! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ there seems to be a lot of extra space in the central hallways and gallery that could be better used inside the rooms..based on approximate dimensions my suggestions include bigger guest bedroom, guest bath, pwdr, laundry and pantry ..upstairs rearranging the master suite and moving the WIL allows for better connection between ens and wiw, more storage walls in wiw, bigger twin vanities, north view for the bath, bigger bed 2 and study nook, separate toilet and better bathroom for sharing Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thank you for your time and response. The sales person mentioned that we can reduce the length of the hallway if the council has any concerns around the width of the house. So we will leave the length of it as per current plan. We are comfortable with the rest of the plan at this stage. I will post the final one once I get an updated version from the builder. Re: First home build - Floor plan review request 14May 22, 2021 8:17 am I'd definitely be upgrading to a wider front door than 820. Perhaps even think about reversing the stairs (unfortunately you'll lose the storage off the garage) and creating a visual feature with the main entry. It will be a little less convenient for traffic up and down, but it will definitely help to acoustically de-couple the two social areas. i thought the flipped plan initially but bec i want narrow pathway from entry to dining (dont like bend), also cannot fit the… 7 17278 1) I had requested R6 ceiling insualtion batts, however I noticed that on some areas there are huge gaps which will allow hot air to sweep in, and also noticed black/grey… 0 3597 6 55347 |
