Browse Forums Building A New House 1 May 10, 2021 11:37 pm Can anyone here who has knowledge/experience in the building industry tell me roughly how much I am looking to build the following Modern French Provincial home? Keep in mind this is not ultra high-end luxury finishes (no real timber, marble or any real stone materials like that), but medium level good quality finishes with lots of detail. Let me know if I have missed any important things below. Specifications ~37 Square Double Story Acrylic Render (unsure if brick or hebel/foam). 4 Bedrooms 2 Bathrooms + Ensuite French Modern Facade French Kitchen + Island (shaker or profile style) + Walk-in Pantry with benchtop & Sink Master bedroom balcony with iron balustrade Master bedroom walk-in robe 40mm stone benchtop kitchen, 20mm stone bench laundry and walkin pantry. Alfresco Kitchen Staircase (French) with timber or iron railing Wall Panelling (French) Cornices/Architraves/Skirtings (French style) Windows (French crosshatch) Windows External Facia (French corbelling detail) Ground Floor 900x900 Tiles First Floor Engineered Timber Mid-level French style bathroom vanities, bathtub French style tapware & sinks Mid-level Kitchen Appliances (smeg, bosch, etc) Ducted Aircon Interior Window Curtains Colorbond windowed garage door Alarm System Large Double Entry Door (Wood/Iron) Sleek Roofing (concrete/terracota) Downlights Interior, French-style Lamps Exterior Optional Extras Concrete Pool 3x6m Landscaping Fencing (rendered fancy) Cobblestone Driveway See below ground floor plans Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ See below first floor plans Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: How much to build this French Modern home? 2May 11, 2021 8:43 am dom0387 Can anyone here who has knowledge/experience in the building industry tell me roughly how much I am looking to build the following Modern French Provincial home? Keep in mind this is not ultra high-end luxury finishes (no real timber, marble or any real stone materials like that), but medium level good quality finishes with lots of detail. Let me know if I have missed any important things below. Specifications ~37 Square Double Story Acrylic Render (unsure if brick or hebel/foam). 4 Bedrooms 2 Bathrooms + Ensuite French Modern Facade French Kitchen + Island (shaker or profile style) + Walk-in Pantry with benchtop & Sink Master bedroom balcony with iron balustrade Master bedroom walk-in robe 40mm stone benchtop kitchen, 20mm stone bench laundry and walkin pantry. Alfresco Kitchen Staircase (French) with timber or iron railing Wall Panelling (French) Cornices/Architraves/Skirtings (French style) Windows (French crosshatch) Windows External Facia (French corbelling detail) Ground Floor 900x900 Tiles First Floor Engineered Timber Mid-level French style bathroom vanities, bathtub French style tapware & sinks Mid-level Kitchen Appliances (smeg, bosch, etc) Ducted Aircon Interior Window Curtains Colorbond windowed garage door Alarm System Large Double Entry Door (Wood/Iron) Sleek Roofing (concrete/terracota) Downlights Interior, French-style Lamps Exterior Optional Extras Concrete Pool 3x6m Landscaping Fencing (rendered fancy) Cobblestone Driveway See below ground floor plans Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ See below first floor plans Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi Dom0387 Build costs vary significantly depending on where you are. Are you able to say what state/locality you are in and that way people from those areas can give you some advice. For example if you are in Sydney we are doing one very similar so I could tell you pretty accurately. cheers Simeon Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: How much to build this French Modern home? 5May 11, 2021 12:13 pm gogo65 Probably $2500/sqm.. Thanks for the feedback, appreciate the ballpark. Question, how did you base this price on just for my better understand. This will help me understand where the money is going so I can either cut back or make changes to those areas to try to save money. I am trying to keep the cost under $1800/sqm Re: How much to build this French Modern home? 7May 11, 2021 12:39 pm dom0387 Location is Sydney Dom0387 I would budget for around $740,000-760,000 for the house, $65,000 for the pool including tiling and glass fencing and around $35,000 for basic landscaping. There is a lot of money in those external decorative features. Without seeing your elevations probably $40-60,000 so if you need to cut costs I would lose those. There is also about $8-10k in the VJ paneling depending on how much you are doing. It costs around $75/m to buy and then it has to be installed You also have added around $6k for the shaker doors, probably $10k for the french style stairs ( I assume you are thinking timber stained treads which are around $400 each and you will need around 18 plus installation & the wrought iron balustrade). To give you a comparison, this style is extremely popular in my neck of the woods on the upper north shore, and there are 2 main builders who specialise in this style and a 400sqm home with one of these guys will set you back around $300-4000/sqm. hope this helps Simeon Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: How much to build this French Modern home? 8May 17, 2021 3:49 pm After receiving revised house plans the total square metres noted in my currently uploaded plans was way off.... by 39m2!
Current plans shows ground + 1st floor total area excluding outdoors = 355m2 (38 square) New plans shows ground + 1st floor total area excluding outdoors = 316m2 (34 square) Will this build cost now less 39m2 make a significant reduction in the total cost, and by how much? $80-100k cheaper? Re: How much to build this French Modern home? 9May 17, 2021 3:54 pm dom0387 After receiving revised house plans the total square metres noted in my currently uploaded plans was way off.... by 39m2! Current plans shows ground + 1st floor total area excluding outdoors = 355m2 New plans shows ground + 1st floor total area excluding outdoors = 316m2 Will this build cost now less 39m2 make a significant reduction in the total cost, and by how much? $80-100k cheaper? Dom0387 Just be careful that the areas shown on your plans are not the FSR calculation figures. Typically designers will only show the FSR calculations so they can track how they are complying against what the local authority will allow. Typically FSR is just the gross floor area (GFA) minus walls, porch, alfresco, 1 garage space, storage and voids. You have to build the GFA area not the FSR area unfortunately. You might want to check this before you pop the champagne regards Simeon Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au 7 11927 I thought this would be a popular question but I haven't been able to find any similar posts. Perhaps I'm wording my searches wrong? When you have car insurance and the… 0 6604 They make the room much easier to clean for one, reflect more light (if light colour tiles are used), and you dont end up with dust on the top edge of tiles (cause most… 3 9542 |
