Browse Forums Building A New House 1 May 07, 2021 11:30 am Re: Gap between cladding and roofing 2May 07, 2021 11:53 am Hey yyf3212 I notice you had another issue with the framer Did You take other framing photos during the Build at the same location above? Cross Check your Construction Wrapping & Flashing details with photos and compare Unfortunately, the photo detail (above) isn't all that clear, nor is it ideal , if on the weather side It's no Secret (Gutters) that gutters leak (humour) Thanks for the photo Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Gap between cladding and roofing 3May 07, 2021 1:47 pm That's very messy work! provided there is a flashing in behind that cladding it should be okay. Normally you want a 10mm gap as the cladding cant sit on the roof tiles ( it will rot) it should be okay. But I cant see the flashing from the photo. Still I think it looks awful and the panel next to it isnt flush so I would be asking for it to be replaced cheers Simeon Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au 2 7546 I plan on installing an undercover walkway (awning ??) from my carport to the back door as shown in sketch. I will be using Boxspan Beams and have no concerns regarding… 0 784 Got my stairs designed like this with 250mm Gap marked below. Gap is bec of 2 steps added between two landing area… 0 4881 |
