Browse Forums Building A New House 1 May 07, 2021 10:06 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Timber or steel framed houses? 3May 07, 2021 7:09 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Timber or steel framed houses? 4May 08, 2021 5:37 am Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Timber or steel framed houses? 5May 08, 2021 7:40 pm SejaeD Kippers01 What are the advantages and disadvantages of light gauge steel frames compared with timber for the customer? Besides being termite safe and before considering pricing and material availability. Kippers01 That is a really interesting question. My team and I are kind of timber framing nerds and we pride ourselves on the quality of our custom frames, but due to the price increases and lack of material we have been forced to make the switch. For readers of the forum who aren't aware, we have had a 47% price increase in 2021 for treated 90x45mm structural grade framing timber and have been advised that another 19% is coming. In real terms a 400 sqm house frame was costing us $54,000 last year and is now close to $80,000. If you can find the timber. From a construction perspective below are the list of advantages/disadvantages that we have found: 1. We love that all the holes for rough ins are pre cut and protected with grommets. This obviously makes rough-ins a hell of a lot faster and you know you have the consistency for quality. 2. We love the flexibility in the web joists that can allow us to run all of our services without cutting holes in our I joists. One of the things we like to recommend to our customers is having seperate air conditioning condensers for upstairs and downstairs, and with I joists we cant run the 300mm ducting so we are forced to use bulkheads. No need for this anymore. Disadvantages, cant really think of any at the moment, other than we miss the flexibility of having our own carpenters drop into bunnings and pick up a few lengths of 90x45mm and the sweet smell of freshly cut timber. Basically we have become big fans of steel in recent times lets hope steel prices don'y increase much. Hope this helps your choice. have a great weekend Simeon Hi Simeon. Just wondering then what is the current cost difference between timber and steel for a 400sqm house? Re: Timber or steel framed houses? 6May 09, 2021 5:27 am MG1981 SejaeD Kippers01 What are the advantages and disadvantages of light gauge steel frames compared with timber for the customer? Besides being termite safe and before considering pricing and material availability. Kippers01 That is a really interesting question. My team and I are kind of timber framing nerds and we pride ourselves on the quality of our custom frames, but due to the price increases and lack of material we have been forced to make the switch. For readers of the forum who aren't aware, we have had a 47% price increase in 2021 for treated 90x45mm structural grade framing timber and have been advised that another 19% is coming. In real terms a 400 sqm house frame was costing us $54,000 last year and is now close to $80,000. If you can find the timber. From a construction perspective below are the list of advantages/disadvantages that we have found: 1. We love that all the holes for rough ins are pre cut and protected with grommets. This obviously makes rough-ins a hell of a lot faster and you know you have the consistency for quality. 2. We love the flexibility in the web joists that can allow us to run all of our services without cutting holes in our I joists. One of the things we like to recommend to our customers is having seperate air conditioning condensers for upstairs and downstairs, and with I joists we cant run the 300mm ducting so we are forced to use bulkheads. No need for this anymore. Disadvantages, cant really think of any at the moment, other than we miss the flexibility of having our own carpenters drop into bunnings and pick up a few lengths of 90x45mm and the sweet smell of freshly cut timber. Basically we have become big fans of steel in recent times lets hope steel prices don'y increase much. Hope this helps your choice. have a great weekend Simeon Hi Simeon. Just wondering then what is the current cost difference between timber and steel for a 400sqm house? For the framing that we do (custom cut on site 90x45mm H2 treated) anywhere between $20-30k. Prices are jumping around so much from job to job when we get them quoted. Last year prices were stable and you could confidently budget $130/sqm this year we are having to budget $190/sqm, and sometimes its still not enough. Im not sure if this is the same with the project guys who use 90x35mm pre made frames. You would think it probably has. And then there's the issue of supply. We went to call up some LVL's the other day (mid job - last timber frame for a while) and were told that there is simply no stock so had to switch to steel beams. cheers Simeon Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Timber or steel framed houses? 7May 10, 2021 12:29 pm couple of other questions.. and apologies if these are dumb 1) noise levels from the steel expanding and contracting from heat... is this a serious issue? 2) any impact on phone/wifi signals 3) mounting pictures/tvs etc on a steel frame.. is there something different that needs to be done here? Re: Timber or steel framed houses? 8May 10, 2021 1:39 pm To prevent expansion/contraction and steel frame acting as a major thermal bridge, it needs to be well insulated from the outside, this is where Hebel would work + rigid (e.g. EPS) insulation attached from the outside of the frame. Normal insulation batts will be at least twice less effective inside steel framing than in timber and insulating in traditional way will be leading to steel contraction/expansion, especially, in the areas where diurnal temperature changes are significant. There might be some impact to wifi and phone signals, however, considering that steel framing is not very dense - this should not very significant. Metal profiles are certainly much faster when it gets to gyprock installations, e.g. whole Knauf system is designed around metal studs for very obvious reasons. Re: Timber or steel framed houses? 9May 10, 2021 1:54 pm skuzy couple of other questions.. and apologies if these are dumb 1) noise levels from the steel expanding and contracting from heat... is this a serious issue? 2) any impact on phone/wifi signals 3) mounting pictures/tvs etc on a steel frame.. is there something different that needs to be done here? Hi Skuzzy no all good questions. Answers are: 1. We insulate our homes really well so there isnt too much noise when compared to the noise that comes from a metal roof 2. Possibly, had no complaints. As standard we run cat 6 cabling throughout especially to all the TV points as we find that wifi isnt that great anyway with all the insulation and hebel floors we put in 3. You just use different screws for the metal frames but we put 12m ply into all the walls where we know the TV's will be mounted to make the process easy for TV installation hope this helps cheers Simeon Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Timber or steel framed houses? 10May 10, 2021 1:55 pm just checking i understood this part correctly.. "Normal insulation batts will be at least twice less effective inside steel framing than in timber and insulating in traditional way will be leading to steel contraction/expansion, especially, in the areas where diurnal temperature changes are significant." Twice less effective - in providing insulation against temperature changes? OR Twice less effective - in limiting the amount of noise from steel contraction/expansion I ve noticed a few builders now are offering (or asking) for steel frame option with color bond roofing (either at no cost or v/cheap upgrade) - but then nothing is said about what changes are being done to the insulation for example. Then reaslitically speaking.. what can be done about this? Prior to the timber shortage, steel frame was already an option.. though i didnt see it being a popular one due to cost. Re: Timber or steel framed houses? 11May 10, 2021 2:49 pm skuzy just checking i understood this part correctly.. "Normal insulation batts will be at least twice less effective inside steel framing than in timber and insulating in traditional way will be leading to steel contraction/expansion, especially, in the areas where diurnal temperature changes are significant." Twice less effective - in providing insulation against temperature changes? OR Twice less effective - in limiting the amount of noise from steel contraction/expansion I ve noticed a few builders now are offering (or asking) for steel frame option with color bond roofing (either at no cost or v/cheap upgrade) - but then nothing is said about what changes are being done to the insulation for example. Then reaslitically speaking.. what can be done about this? Prior to the timber shortage, steel frame was already an option.. though i didnt see it being a popular one due to cost. if you end up going with a project home builder they will only install the minimum insulation as required by basix. Depending on your climate zone this will probably be R2.0 to external walls and R.4.0 or 5.0 in the ceiling in my opinion to do it properly you need to sark every external wall and tape the sheets tight. all external penetrations need to be filled with expandable foam and ideally you need expandable foam behind the studs. you should also install insulation in all internal walls and between your floors. There is a reason that project home builders deliver a much lower upfront cost regards Simeon Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14449 This is 100% true. You can not hang anything on steel frames. very frustrating 8 8036 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15923 |
