Browse Forums Building A New House Re: Data Cabling - Hampshire 45A - Metricon 8Apr 15, 2021 1:24 pm Follow my build here: https://www.instagram.com/ivy5custom Re: Data Cabling - Hampshire 45A - Metricon 14Apr 16, 2021 6:41 pm Renman Spazzen I'm having my NBN box moved from the garage to the walk in linen, its central to the house so better for the wifi and i feel more comfortable keeping the NAS in there above the shelf than in the garage where anyone walking past can spot it when the door opens and closes. When my parents built they had it put in the void under the stairs along with a full server rack for home automation. You may notice the humming of the fan from the server and the switch that could be annoying. Should be fine, i'll be using the top shelf of the cupboard to hold the equipment rather than a rack so i'll be using a standard form server instead a noisier rack mounted one. I'll also only have an 8 port gigabit router in there so it shouldnt make much noise, I've got a data run and power for a second router in the roof cavity to handle the data runs for POE security cameras. the WIL also backs onto the WIP on one end and the hallway on the other so area's that don't matter much if theres some noise bleed. Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented… 21 20675 If you're referring to Eufy homebase, then just put a switch between a datapoint and put the homebase elsewhere near another device in your home unless you want teh… 9 13863 Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 10759 |
