Build over/next sewer and overland flow
Page 1 of 2
Find someone independent to do a site and cost analysis before you engage with any new home salesman
You'll need a survey, geotech report, Engineering and details, you can enquire with the water Corp engineers
To put things into perspective a salesman's job is to sign you up, get a deposit, allow other to sort things out, for which they get paid a Big Commi$$ion
At worse they are allowed to make mistakes, leave things out and underestimate costs
and many a client has been told that in the Builders office after Preparation of Plans when firming up estimates.
This link tells you the requirements for BAS:
https://www.sydneywater.com.au/web/groups/publicwebcontent/documents/document/zgrf/mdc2/~edisp/dd_076198.pdf
If you register will DBYD (free takes 2 minutes) you can find depth/location, type etc of sewer and how much space you have.
https://www.1100.com.au/
It might also show if encasement required for neighboring houses if not SW have the info but I'm not sure if you need to open a file or something with them or if they have a general chit chat helpline
Building over or next to assets (sydneywater.com.au)
Usually if a SW asset under a site it will be a condition of the DA that SW consent is obtained prior to CC via 'tap in'. Perhaps its a provisional amount or something-ask the builder why encasement required. Probably will be a few piers to below zone of influence but Id get the geotech report done first if not already.
I also registered with SW, very easy to use.
Down load the pdf notes that generally accompany the maps it will help with interpreting the data, dos and don'ts,etc
You're looking for the size pipe, invert level, manhole, info ,etc
Your engineer will certify pile details, centres and depth
OT, generally they don't allow for encasement here in WA as there are easements
Cheers
Chris
Here is a couple of my previous posts with drawings
viewtopic.php?f=1&t=69324&hilit=sewer+encasement
viewtopic.php?f=31&t=98872&p=1870511&hilit=sewer+encasement#p1870511
@ Chris. We have had several quotes from arborists , excavators and others both recently and in the past who say they won't accept the DBYG drawings as they can sometimes be way off. Generally I've found them to be roughly right but a mate found one pipe that was at least a metre away from where it should have been.
I'll get one for our place when we are nearer to demo ( for the relevant officials ) but i've already done careful exploratory digging, located all pipes on our nature strip adjacent to our two side boundaries and logged the depths and positions on a sheet.
A much better method in my book.
Stewie
If it is Sydney Water, you will have to engage a water services coordinator who act as a sort of middleman between the client and Sydney Water. They will organise the pegout. Has Wisdom homes given you a copy of the plans yet as the WSC will need the plans, a survey etc. Once they have that you will need an engineer to give them a drawing for what is needed at the house construction stage showing the piers, footings etc in relation to the sewer.
Stewie
Stewie
Hi Stevie,
Lots of useful information in that post, thanks.
It is Sydney water, I thought that if we pier down past the zone of influence to avoid possible problems with the sewer pipe and not actually concrete encasing them. But It seems like that Sydney water make you to encase the pipe and pier down pass the zone of influence within 2 m of their asset.
I designed my house smaller than what we want due to this issue, if we need encase it anyway I may want to design a bigger house to build over the pipe.
Current building plan is to build next to it (within 2m), it’s mainly the garage side.
Stewie
We are having our sewer concrete encased on Friday. As you can see in my drawings there are no piers as it is all on rock and is because we have two retaining walls straddling it. We are also having out point of discharge moved 3m downstream to give us more fall from the basement ensuite that is going to be under our rear terrace. All up it is going to cost us just shy of $10k.Other quotes were similar. Some quoted around $6,000 for just the two concrete encasements.
Stewie
Stewie
In addition, there is a stormwater easement next to the sewer pipe close to the boundary. Do you know how close I can build next to the store water line? I searched online it says 1m away from the outside edge, is this info correct?
Stewie
Stewie
I tried to ask our builder, they tended to ask you to sign the tender and pay deposit then start this process. I don’t want to lock myself into something I don’t know how much it’s going to cost me.
Stewie
10k for building adjacent provision and 20k allowance for encasement is ours
Lindsaytam
So you can compare, it costs us around $600/lineal metre to encase a sewer and then you have to allow some money fo design fees and other stuff. So if you are encasing a 10m sewer it would be fair to allow a budget of $1000/metre or $10,000 as a guide
good luck
Simeon
Stewie
3
You may still have a case, but your next step is to speak to a lawyer.
17/06/2023
Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m…
29/01/2024
3
I think you are getting different numbers because they all just based them on "other jobs" even though each job is unique. Often, with builders, unless you're speaking to…
