Browse Forums Building A New House 1 Mar 13, 2021 8:20 pm Hi, Bit of an unusual situation, To comply with my estate guidelines I need to install a natural finished timber pergola for my new house being built. My builder has included a treated pine pergola to address this, I intend to paint this white six months post installation. If I intend to paint the pergola white but need the treated pine protected during the first six months what would be the best product to use? Basically must allows easy paint over whilst protecting the timber etc. Thanks in advance , pic attached Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Advice needed on painting over stained treated pine 2Mar 15, 2021 8:32 am Bcr83 Hi, Bit of an unusual situation, To comply with my estate guidelines I need to install a natural finished timber pergola for my new house being built. My builder has included a treated pine pergola to address this, I intend to paint this white six months post installation. If I intend to paint the pergola white but need the treated pine protected during the first six months what would be the best product to use? Basically must allows easy paint over whilst protecting the timber etc. Thanks in advance , pic attached Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ My advice would be to check with your local paint store for exact technical advice, but in theory I don't see why you cant use a clear or light coloured stain/sealant now and then give it a light sanding with say 150 grit before painting. Cheers Simeon Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6585 Iām just in the process of replacing 2 stud walls that have been severely damaged by termites and am planning to use h2 blue pine. I just wanted to if anyone can advise… 0 52857 Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 10972 |
